MacBook Pro 15" Model A1150 Display Components
Grab a toolkit for your MacBook Pro 15" Model A1150 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
MacBook Pro 15" (Models A1150/A1211) Display Data Cable
A damaged display data cable can cause video defects
MacBook Pro 15" (Model A1150) Inverter/iSight Cable
MacBook Pro 15" (Models A1150/A1211) Display Inverter
A bad inverter board can cause a dead backlight
MacBook Pro 15" (Model A1150) Clutch Cover
Houses the hinges and airport antenna assembly.
MacBook Pro 15" (Model A1150) Antenna Cover
This antenna cover houses the airport antenna assembly compatible with the Model A1150 EMC 2101 15 inch MacBook Pro laptop. Part #922-7279.
MacBook Pro 15" (Models A1150/A1211) Rear Display Bezel
Replace a damaged bezel without the cost of a new LCD
기기 정보
The MacBook Pro 15" Core Duo model A1150 was the first of many laptops to be named "MacBook Pro." It features an aluminum casing, just like the PowerBook G4 before it, but this model includes a built-in web camera called iSight and a MagSafe power connector.
The most common repairs with the model A1150 15" MacBook Pro are replacing a dead battery, replacing a malfunctioning left or right fan, and upgrading the hard drive or RAM. The MacBook Pro 15" Model A1150 Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 2 GB of RAM. Tired of waiting while your files transfer over a slow wireless network? You can even upgrade the laptop's wireless card to a 802.11n AirPort Extreme Card. In addition, you can install a 8x SuperDrive for faster burning speeds.
Once you've bought your parts and tools, check out iFixit's A1150 MacBook Pro 15" repair guides for step-by-step instructions on how to make the fix.
