부품 Mac MacBook Pro 15" Touch Bar Mid 2017 Hard Drive Enclosures
상점
Grab a toolkit for your MacBook Pro 15" Touch Bar Mid 2017 model and fix a broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
모델명을 모르십니까? Mac ID 찾기
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
US$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
US$7.99
MacBook Pro 15" Retina (Late 2016-2017) Battery / Fix Kit
Replace a dead or malfunctioning battery compatible with a MacBook Pro 15" Retina (Late 2016/2017).
US$129.99부터
MacBook Pro 15" Retina (Late 2016-2019) Left Speaker
Replace a damaged or malfunctioning speaker compatible with a Late 2016 to 2019 model MacBook Pro 15" with Touch Bar.
US$24.99
MacBook Pro 15" Retina (Late 2016-2019) Right Speaker / New
US$14.99부터
MacBook Pro 13"/15" Retina (Touch Bar, Late 2016-2017) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard.
US$149.99
MacBook Pro 15" Retina (Late 2016-2019) Left Fan
Replace a defective or noisy fan compatible with a 2016 to 2019 model 15" MacBook Pro with Retina Display.
US$49.99부터
MacBook Pro Retina (Late 2016-Mid 2017) Plastic Feet
Replace missing or damaged black plastic feet on the lower case of your laptop.
US$4.99
MacBook Pro 15" Retina (Late 2016-2019) Display Cable
Replace the short flex cable that connects the display daughter board to the logic board.
US$19.99부터
MacBook Pro 15" Retina (Late 2016-2019) Heat Sink / Used
Replace a damaged heat sink compatible with a 2016 to 2019 model 15" MacBook Pro with Retina Display.
US$39.99부터
제품 보기 32개 중 1 - 10개
기기 정보
Released in June 2017 as model A1707, this MacBook Pro features Kaby Lake processors up to the 2.9GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.9GHz.
The most common repairs with the 15" MacBook Pro Retina Mid 2017 laptops are replacing a dead battery, replacing a malfunctioning left or right fan, or a damaged display assembly.
The battery in a MacBook Pro 15" Retina Mid 2017 is adhered to the inside of the upper case. Our replacement batteries include the needed adhesive.
The MacBook Pro 15" Mid 2017 models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Retina Display Mid 2017 repair guides for step-by-step instructions on how to make the fix.
