MacBook Pro 15" Unibody Late 2011 Case Components
Grab a toolkit for your MacBook Pro 15" Unibody Late 2011 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpad
Replace a trackpad compatible with the Mid 2009 to Mid 2012 model A1286 MacBook Pro 15 inch Unibody laptop. Part #922-9035, 922-9306, 922-9749.
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Upper Case
Replace an upper case, backlit keyboard, and battery level indicator assembly compatible with the Early 2011 to Mid 2012 15 inch MacBook Pro Unibody laptop.
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Airport/Bluetooth Bracket
Replace a bracket that houses the Airport and Bluetooth board compatible with the Early 2011 to Mid 2012 Unibody 15 inch MacBook Pro laptop. Part #076-1380.
MacBook Pro Unibody (Mid 2009-Mid 2012) Trackpad Mounting Screws
Replacement screws and springs for mounting the trackpad in the upper case assembly of your mid 2009 to mid 2012 13" and 15" MacBook Pro Unibody laptop.
MacBook Pro 15" Unibody (Mid 2010-Mid 2012) Lower Case
Replace a broken or damaged lower case for your Mid 2010 to Mid 2012 MacBook Pro 15" Unibody with this part. This part includes 4 rubber feet.
기기 정보
The Late 2011 version of MacBook Pro 15" Unibody is virtually identical to the Early 2011 model except for a CPU and graphics upgrade. It features a quad core Core i7 processor with PC3-10600 RAM. It also sports the new Thunderbolt standard allowing 10 Gbps transfer speeds in both directions.
The most common repairs with Late 2011 model MacBook Pro 15" Unibody laptops are replacing a dead battery, replacing a malfunctioning left or right fan, and upgrading the hard drive or RAM. The MacBook Pro 15" Unibody (Late 2011) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 16 GB of RAM.
The Late 2011 model MacBook Pro 15" Unibody requires a Tri-point Y0 Screwdriver to remove the battery. Our battery repair kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Unibody Late 2011 repair guides for step-by-step instructions on how to make the fix.
