내 문제
lightning cable port would't charge , only would charge with new Apple cables. thought it may have been from using crappy cheap cables for years
나의 수리
I purchased a used cable witch came well packaged and in a static free sealed bag. Followed the guide and it all went very well. Although the guide had called for removing the battery. I would have happily done so had I had replacement adhesive strips, but some other users suggested that it was possible without removing it. I took my chances and they were right it was possible. but it would have been a little easier with it removed.
내 조언
if you have the adhesive strip, go ahead and remove the battery, it will make the job easier. And be patient reattaching the antenna cable, it will go but it taked a steady hand
댓글 0개
