내 문제
Had a cracked corner for the last 2 years and the battery was taking 6 hours to charge and lasted only 8-10 hours.
나의 수리
The repair went great, the instructions were easy to follow, no issues at all.
내 조언
People should not expect the screen to have the same depth of color, richness, or fullness of their original screen, everything is a bit lighter in color with the replacement. Also, I'm assuming this is a defect in the replacement screen I received, but there is a small area above the home button that has distorted pixels, like when you press on an LCD screen and you get ghosting, but this ghosting doesn't go away. It's a bit hard to see in the pics posted, but if you look close you can see it. And no, they do not show up in a screenshot, there is a mechanical issue with the screen.
댓글 0개
