내 문제
Original battery did not hold a charge. It was basically unusable for more than 5-8 minutes without being plugged in.
나의 수리
Was pretty straight forward, the hardest part was removing the battery. The adhesive solvent needed closer to 5 minutes to loosen the adhesive. The tools that came with the battery were excellent.
내 조언
Make sure you use something to keep the screws separated and labeled, I used a towel to prevent the screws from rolling away and labeled with painters tape.
댓글 0개
