주요 콘텐츠로 건너뛰기
해당 분해도는 수리 안내서가 아닙니다. Acer Nitro 5 AN517-52 수리는 자사의 서비스 설명서를 사용하세요.
  1. Acer Nitro 5 AN517-52 Basic Teardown, Remove the back cover: 1 단계, 이미지 1개 중 1개
    • Remove the 12 Philips screws on the back. Slip fingernails in cracks and snap open the back all around. Be gentle and it will come off.
  2. Acer Nitro 5 AN517-52 Basic Teardown, Replace battery: 2 단계, 이미지 1개 중 1개
    • Remove the 2 Philips screws holding the battery. Gently twist counter-clockwise to release the corners. Unplug the connector straight, without twisting.
  3. Acer Nitro 5 AN517-52 Basic Teardown, Clean fans: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Fans are great at removing dust from the room then do not work well. Look at the right fan in the picture - dusty. Some dust can be removed with tweezers. Other dust can be blown off with a can of compressed air but put a finger on the fan to prevent it from spinning. Note that replacing the fans is not simple due to heatsink complications.
  4. Acer Nitro 5 AN517-52 Basic Teardown, SSD/HDD replacement: 4 단계, 이미지 1개 중 1개
    • Replacement of the SSD/HDD is suprisingly simple. Remove the 4 Philips screws, slide the drive straight to the side.
  5. Acer Nitro 5 AN517-52 Basic Teardown, Button cell replacement: 5 단계, 이미지 1개 중 1개
    • The small button cell is in black heatshrink, held in with one connector only. Unplug it. If you know what you are doing, solder in a new one otherwise replace the assembly.
  6. Acer Nitro 5 AN517-52 Basic Teardown, Replace speakers: 6 단계, 이미지 1개 중 1개
    • I you crank up the toons [sic] too much and break a speaker, they are simple to replace. Unscrew them and unplug the connectors.
    • Keyboard replacement is quite involved and susceptible to fatal damage to the laptop due to connector damage. It involves removing the battery, fans/heatsink assembly, I/O boards, shields, mother board and cutting plastic standoffs, then plastic welding them back with the new kbd. This procedure will not be covered here.
작성자
3다른 기여자 명과 함께
AlStu
회원 가입일: 11/20/22
145 평판
안내서 1개를 작성함
댓글 한 개
Quick question for you, are those two fans identical or are they different? Looking to replace mine and found a single one on Amazon and I want to know if it’ll work on both sides if I buy two.
Skid-Wheel Playz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 97
지난 30일: 378
전체 시간: 8,840
