해당 분해도에 사용된 도구
소개
REMEMBER to record (like, take photos of) screws you removed. Some are fine metal thread type and others are coarse self-tap for plastic. Do not mix them!
Canon EOS M5
Remove the strap, Or, it WILL cause mess during the teardown/repair. Remove it unless you are as SKILLFUL (lazy) as I am.
FIRST remove battery and SD card.
remove 1 self-tap screw
remove 6 screws
These 2
And these 4
Gently, lift (towards back) and slide the back cover towards left (THE LEFT when you holding the camera)
Disconnect 2 FPC.
Remove 3 screws near the EVF. REMEMBER lengths and hole positions. The center one is longer. The left holes.
Pop the speedlight (flash)
Remove the screw covered by the speedlight.
Now the front case comes off.
There are some clips, be gentle and patient.
Please keep body cap on as possible, for shielding again dust.
Front cover comes off with 2 small parts. Don't loose them.
The capacitor
To avoid electric shock and damage, DISCHARGE IT with a 2kohm~10kohm resistor for more than 15 seconds, ASAP!!!
Remove EVF plastic case.
There are some clips.
Remove 1 screw, REMEMBER from which hole!
Detach FPC.
Be gentle enough We do NOT remove top case. Because it's kind of messy with some adhesive...
When the top case is loosen. remove the metal frame.
Or you can remove this BlueTooth board if not being lazy.
IF you can count to 5:
PCB top left, detach 2 FPC. 1 ZIF, 1 non-ZIF
PCB top right, detach 4 FPC and 1 cable connector
PCB top center. detach sensor cable.
Ladies and gentlemen, the mother board
Digic and RAM
RTC battery
Some Flash
SD socket
Some power supply
댓글 4개
Thank You!!
Is there a way to remove and replace the rubber eye cup without disassembly?
Does anybody know where to buy screws shown on step 6 or what size they are? One of those fell out of my camera.
