이 번역은 원본 안내서의 최신 업데이트를 반영하지 않을 수 있습니다. 번역 업데이트를 돕거나 아니면 원본 안내서 보기를 참조하세요.
소개
We will not be tearing the whole thing apart; just the big pieces
This loudspeaker was tinkered at the charge port (installation of a new one).
필요한 것
동영상 개요
Use a plastic spatula or credit card to open the grids
You should not have to exert too much force on the grids. There is a little bit of glue on it.
Remove the first 4 screws
Blow up the round of plastic then take care of the remaining 4 screws.
Now you can access the motherboard.
To disconnect the battery: disconnect the microphone first, it will make things easier.
Unscrew the two screws of the white cover
Get out of his notch, and here's the battery!
다른 10명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
83%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 13개
About to try this, will give feedback
This is the charge2 + not the charge2
The Daniel - 답글
there aren,t any screws in the cap
I have the same problem. I think this is a TL model, but I have not been able to find any information on how to correctly remove the end caps. I don’t want to scratch or break anything trying to pop the end caps off.
Bobcov -
Thanks so much! I had a broken bit of plastic inside the tube after I left my speaker in my checked luggage and it got smashed around. I followed the instructions and managed to get it out, the speaker is purring again without the annoying ass rattle!! You're a legend my friend. TY
itgotfixed - 답글
