주요 콘텐츠로 건너뛰기
해당 분해도는 작업 중 입니다 – 최신 변경 사항을 보려면 주기적으로 다시 로드 하십시오!
해당 분해도에 사용된 도구
소개
How to take apart the M6013 Capacitor Meter
  1. Remove the circled screw Remove battery case and batteries
    • Remove the circled screw
    • Remove battery case and batteries
  2. Remove circled screws Pull case apart Watch out for buttons, they will fall out easily.
    • Remove circled screws
    • Pull case apart
    • Watch out for buttons, they will fall out easily.
  3. Remove circled screws Be careful when removing the circuit board, the battery cable is still connected. Unsolder the square locations either on the circuit board or the case to fully remove the circuit board
    • Be careful when removing the circuit board, the battery cable is still connected.
    • Unsolder the square locations either on the circuit board or the case to fully remove the circuit board
  4. Location of microprocessor Location of microprocessor
    • Location of microprocessor
  5. Remove the cable connector Remove Display
    • Remove the cable connector
    • Remove Display
Ted Hsueh
회원 가입일: 2012년 09월 20일
170 평판
안내서 3개 작성하였습니다
Cal Poly, Team 16-56, Forte Fall 2012 Cal Poly, Team 16-56, Forte Fall 2012 회원
CPSU-FORTE-F12S16G56
5 회원들
안내서 7개 작성하였습니다
Add some specs on start and foto of the unit ....
Mateusz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 410
