주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Motorola Moto G 1st Generation 수리는 저희 서비스 설명서를 사용하십시오.
  1. Motorola Moto G 1st Generation Teardown, Motorola Moto G 1st Generation Teardown: 1 단계, 이미지 1/3 Motorola Moto G 1st Generation Teardown, Motorola Moto G 1st Generation Teardown: 1 단계, 이미지 2/3 Motorola Moto G 1st Generation Teardown, Motorola Moto G 1st Generation Teardown: 1 단계, 이미지 3/3
    • After removing the back cover, use a torx T5 to remove all screws at the back
    • Use an opening tool or plastic spuged to remove the outer frame.
  2. Motorola Moto G 1st Generation Teardown: 2 단계, 이미지 1/3 Motorola Moto G 1st Generation Teardown: 2 단계, 이미지 2/3 Motorola Moto G 1st Generation Teardown: 2 단계, 이미지 3/3
    • First we're going to remove the battery
    • Using a plastic spudger, remove the battery connector from its socket.
    • The battery will come off the motherboard when you put a little bit of pressure under it.
    • Don't bend the battery too much
  3. Motorola Moto G 1st Generation Teardown: 3 단계, 이미지 1/1
    • The naked motherboard will reveal 2 connectors (apart from the battery-socket)
    • This is the front-cam
    • This is the digitizer/LCD flex
  4. Motorola Moto G 1st Generation Teardown: 4 단계, 이미지 1/3 Motorola Moto G 1st Generation Teardown: 4 단계, 이미지 2/3 Motorola Moto G 1st Generation Teardown: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • To remove the camera, use a pair of tweezers to remove the tape
    • Next, use a plastic spudger to open up the socket.
    • Pull the camera up (out of the lens-socket) and pull so the flex will come out of it's socket
  5. Motorola Moto G 1st Generation Teardown: 5 단계, 이미지 1/3 Motorola Moto G 1st Generation Teardown: 5 단계, 이미지 2/3 Motorola Moto G 1st Generation Teardown: 5 단계, 이미지 3/3
    • To remove the LCD/Digitizer connection from its socket, remove the blue silicone cover
    • Next, use a plastic spudger to open the socket-lock
    • Carefully remove the flex cable.
    • Although this flex seems to exist in 2 parts, it's actually removable as one. Only the wide flex has to be disconnected.
  6. Motorola Moto G 1st Generation Teardown: 6 단계, 이미지 1/1
    • Now, it's only the motherboard that's left.
    • Use a fine plastic tool to pull the main board out
    • There are no screws at this step
    • Never put too much stress on the motherboard, find other places to put pressure if it doesn't cooperate immediately
  7. Motorola Moto G 1st Generation Teardown: 7 단계, 이미지 1/1
    • All done
    • The earpiece remains in the screen assembly. Take care when removing it from the screen. Push gently on it from the screen-side to lift it out.
Maxim
회원 가입일: 04/30/14
2,297 평판
안내서 3개 작성하였습니다
iFixers Belgium iFixers Belgium 회원
Business
1 회원
안내서 5개 작성하였습니다
댓글 22개
The procedure is very simple, but i realise that take off all the screws is a little bit difficult. As well, remove the motherboard that is attached to the plate behind the screen.
Allan Alcantara - 답글
Question. How difficult is it to replace the glass?
Abigail McElroy - 답글
I'm just about to have a go at it now!
I'll let you know
Dan Cameron -
Just replaced the broken screen on my XT1039. Be aware XT1032,XT1033, XT1039 - the screen components are all the same. I bought the screen/frame/digitizer as one unit for the XT1032. It was relatively straight-forward with a bit of care and attention in certain areas. After you've taken the 14 screws out the rest of the phone is basically glued together with sticky-strips. I followed the advice on a You-tube video and used a hair dryer to heat up the ribbon cables and to loosen the earpiece. Phone now fully functional - hooray! Thanks to all on this forum!
camiano - 답글
Can we further dismantle individual elements on motehrboard? Like I want to replace the memory.
simplyviral - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 62
전체 시간: 88,870
