주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Nikon 1 J5 수리는 저희 서비스 설명서를 사용하십시오.
  1. Nikon 1 J5 Teardown (repair purpose), Nikon 1 J5 Teardown (repair purpose): 1 단계, 이미지 1/2 Nikon 1 J5 Teardown (repair purpose), Nikon 1 J5 Teardown (repair purpose): 1 단계, 이미지 2/2
    • Remove Lens, MicroSD Card and Battery
  2. Nikon 1 J5 Teardown (repair purpose), Remove/Replace LCD/Touchscreen: 2 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose), Remove/Replace LCD/Touchscreen: 2 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose), Remove/Replace LCD/Touchscreen: 2 단계, 이미지 3/3
    • Remove 2 screws first
    • Lift the cover
    • Disconnect LCD FPC
    • Then remove 4 screws
    • Remove LCD assembly
  3. Nikon 1 J5 Teardown (repair purpose), The LCD assembly and FPC connector: 3 단계, 이미지 1/2 Nikon 1 J5 Teardown (repair purpose), The LCD assembly and FPC connector: 3 단계, 이미지 2/2
    • Insert wisdom here.
  4. Nikon 1 J5 Teardown (repair purpose), Bottom side: 4 단계, 이미지 1/1
    • Remove 2 screws
  5. Nikon 1 J5 Teardown (repair purpose), Left Side(The LEFT when you holding it the right way): 5 단계, 이미지 1/1
    • Open connection bay
    • Remove 2 screws
  6. Nikon 1 J5 Teardown (repair purpose), Right side(the RIGHT when you holding it the right way): 6 단계, 이미지 1/1
    • Remove 1 screw under the DC power cable notch cover
  7. Nikon 1 J5 Teardown (repair purpose), Back side(again): 7 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose), Back side(again): 7 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose), Back side(again): 7 단계, 이미지 3/3
    • Remove 4 screws and be ware the length difference
    • Peel the rubber open from right hand side
    • Remove 1 screw
  8. Nikon 1 J5 Teardown (repair purpose), Back case: 8 단계, 이미지 1/2 Nikon 1 J5 Teardown (repair purpose), Back case: 8 단계, 이미지 2/2
    • Now the back case can be removed.
    • There's no fragile FPC or cables in this step. Just be patient.
  9. Nikon 1 J5 Teardown (repair purpose), Keypad: 9 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose), Keypad: 9 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose), Keypad: 9 단계, 이미지 3/3
    • Disconnect speaker cable
    • Pull out keypad cable
  10. Nikon 1 J5 Teardown (repair purpose): 10 단계, 이미지 1/2 Nikon 1 J5 Teardown (repair purpose): 10 단계, 이미지 2/2
    • Insert small crowbar or flat head screw driver here to lift the keypad up.
    • Those clips are very tight.
  11. Nikon 1 J5 Teardown (repair purpose), Shielding cover: 11 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose), Shielding cover: 11 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose), Shielding cover: 11 단계, 이미지 3/3
    • Remove 3 screws
    • Remove 2 screws
    • Notice the sizes of screws
  12. Nikon 1 J5 Teardown (repair purpose), Shielding cover: 12 단계, 이미지 1/1
    • Need some tape peeling
  13. Nikon 1 J5 Teardown (repair purpose), Discharge flash reservoir capacitor: 13 단계, 이미지 1/1
    • Dangerous DC Voltage > 200V, stored in a 330V 80uF capacitor set.
    • Flash xenon tube terminals, positive connected to capacitor, negative controlled by circuit, and a trigger signal.
    • Use 10kohm, >2W resistor, connect 2 solder joints for more than 5sec. These are flash condenser/capacitor terminals. DO NOT discharge by SHORT them. (Note 2020-10-13)
    • DMM's Low-Z voltage works even better, also safer.
    • Measure voltage between 2 solder joints to ensure voltage <10V
  14. Nikon 1 J5 Teardown (repair purpose), FPC connectors: 14 단계, 이미지 1/1
    • Flash solenoid and detecter
    • Microphones and AF assistant LED
    • Keypad
    • Switches
    • NFC
    • WiFi and Bluetooth, Lens(back)
    • CMOS sensor
    • LCD
  15. Nikon 1 J5 Teardown (repair purpose), Main PCB 1: 15 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose), Main PCB 1: 15 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose), Main PCB 1: 15 단계, 이미지 3/3
    • Detach every FPC you can find
  16. Nikon 1 J5 Teardown (repair purpose), Main PCB 2: 16 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose), Main PCB 2: 16 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose), Main PCB 2: 16 단계, 이미지 3/3
  17. Nikon 1 J5 Teardown (repair purpose), Main PCB 3: 17 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose), Main PCB 3: 17 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose), Main PCB 3: 17 단계, 이미지 3/3
    • Desolder flash condenser FPC and Flash cables (remember to discharge first)
  18. Nikon 1 J5 Teardown (repair purpose), Main PCB 4: 18 단계, 이미지 1/2 Nikon 1 J5 Teardown (repair purpose), Main PCB 4: 18 단계, 이미지 2/2
    • More FPC
  19. Nikon 1 J5 Teardown (repair purpose), Main PCB 5: 19 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose), Main PCB 5: 19 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose), Main PCB 5: 19 단계, 이미지 3/3
    • Lift Main PCB, SLOWLY and GENTLY
    • One more FPC at the back side.
  20. Nikon 1 J5 Teardown (repair purpose), Behold, The Main PCB: 20 단계, 이미지 1/2 Nikon 1 J5 Teardown (repair purpose), Behold, The Main PCB: 20 단계, 이미지 2/2
  21. Nikon 1 J5 Teardown (repair purpose): 21 단계, 이미지 1/2 Nikon 1 J5 Teardown (repair purpose): 21 단계, 이미지 2/2
    • Mark 3 screws for their ID and position.
    • Also record how many turns to the limit.
    • Measure and record distance to front flange if possible.
    • These screws will affect focus focal plain.
  22. Nikon 1 J5 Teardown (repair purpose), Behold, the sensor: 22 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose), Behold, the sensor: 22 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose), Behold, the sensor: 22 단계, 이미지 3/3
    • Sensor module and IR-cut filter
  23. Nikon 1 J5 Teardown (repair purpose), Remove IR-cut: 23 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose), Remove IR-cut: 23 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose), Remove IR-cut: 23 단계, 이미지 3/3
    • Hold the IR-cut filter by its edge, to avoid scratches and contamination.
    • Use plastic tweezers can avoid scratches.
  24. Nikon 1 J5 Teardown (repair purpose), The sensor itself: 24 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose), The sensor itself: 24 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose), The sensor itself: 24 단계, 이미지 3/3
    • And I don't quite remember what is this filter/window.
  25. Nikon 1 J5 Teardown (repair purpose), Battery bay: 25 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose), Battery bay: 25 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose), Battery bay: 25 단계, 이미지 3/3
    • remove 2 self tap screws (upper and lower)
    • Sorry for the magical color change of victim camera and chaotic white balance on of my desk(mixed warm LED and flash).
  26. Nikon 1 J5 Teardown (repair purpose), The battery bay: 26 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose), The battery bay: 26 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose), The battery bay: 26 단계, 이미지 3/3
  27. Nikon 1 J5 Teardown (repair purpose), Top Case 1: 27 단계, 이미지 1/2 Nikon 1 J5 Teardown (repair purpose), Top Case 1: 27 단계, 이미지 2/2
    • Pop up flash by pulling up the solenoid
    • Remove screw in flash bay
  28. Nikon 1 J5 Teardown (repair purpose), Top case 2: 28 단계, 이미지 1/2 Nikon 1 J5 Teardown (repair purpose), Top case 2: 28 단계, 이미지 2/2
    • Remove 2 self tap screws
  29. Nikon 1 J5 Teardown (repair purpose), Top Case 3: 29 단계, 이미지 1/2 Nikon 1 J5 Teardown (repair purpose), Top Case 3: 29 단계, 이미지 2/2
    • Now you can wiggle off top case.
    • Only 3 small clips
  30. Nikon 1 J5 Teardown (repair purpose), Flash head: 30 단계, 이미지 1/2 Nikon 1 J5 Teardown (repair purpose), Flash head: 30 단계, 이미지 2/2
    • Remove this screw
    • Remove flash head
  31. Nikon 1 J5 Teardown (repair purpose), Top case 4: 31 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose), Top case 4: 31 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose), Top case 4: 31 단계, 이미지 3/3
    • Top Case
    • AF assistant LED and left Microphone
    • Switch board. Right microphone, power switch, shutter button, mode dial, main command dial.
  32. Nikon 1 J5 Teardown (repair purpose): 32 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose): 32 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose): 32 단계, 이미지 3/3
    • screws
    • FPC
    • Sneaky screw
  33. Nikon 1 J5 Teardown (repair purpose), Mode dial cap: 33 단계, 이미지 1/2 Nikon 1 J5 Teardown (repair purpose), Mode dial cap: 33 단계, 이미지 2/2
    • Mode dial cap is double sided taped,
    • Remove switch board.
    • Someone else already murdered the main dial and video record button...
  34. Nikon 1 J5 Teardown (repair purpose): 34 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose): 34 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose): 34 단계, 이미지 3/3
    • Light guide
    • other angles
  35. Nikon 1 J5 Teardown (repair purpose), Mode Dial: 35 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose), Mode Dial: 35 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose), Mode Dial: 35 단계, 이미지 3/3
    • Sneakier screw
  36. Nikon 1 J5 Teardown (repair purpose), Power switch and shutter button: 36 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose), Power switch and shutter button: 36 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose), Power switch and shutter button: 36 단계, 이미지 3/3
    • sc...s
  37. Nikon 1 J5 Teardown (repair purpose), Sensor and focus adj: 37 단계, 이미지 1/1
    • Focus adjust and focal plane calibration is important to par-focal lenses
  38. Nikon 1 J5 Teardown (repair purpose), Battery latch: 38 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose), Battery latch: 38 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose), Battery latch: 38 단계, 이미지 3/3
  39. Nikon 1 J5 Teardown (repair purpose), Lens mount: 39 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose), Lens mount: 39 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose), Lens mount: 39 단계, 이미지 3/3
    • and lens contacts
  40. Nikon 1 J5 Teardown (repair purpose), Lens contacts: 40 단계, 이미지 1/2 Nikon 1 J5 Teardown (repair purpose), Lens contacts: 40 단계, 이미지 2/2
  41. Nikon 1 J5 Teardown (repair purpose), take apart everything: 41 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose), take apart everything: 41 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose), take apart everything: 41 단계, 이미지 3/3
  42. Nikon 1 J5 Teardown (repair purpose), Flash capacitor: 42 단계, 이미지 1/2 Nikon 1 J5 Teardown (repair purpose), Flash capacitor: 42 단계, 이미지 2/2
    • Capacitor / condenser, which do you prefer?
  43. Nikon 1 J5 Teardown (repair purpose), Wireless module: 43 단계, 이미지 1/3 Nikon 1 J5 Teardown (repair purpose), Wireless module: 43 단계, 이미지 2/3 Nikon 1 J5 Teardown (repair purpose), Wireless module: 43 단계, 이미지 3/3
    • WiFi and bluetooth
    • Lens latch pin
  44. Nikon 1 J5 Teardown (repair purpose), Wiireless module: 44 단계, 이미지 1/2 Nikon 1 J5 Teardown (repair purpose), Wiireless module: 44 단계, 이미지 2/2
    • This one is liquid damaged
  45. Nikon 1 J5 Teardown (repair purpose), NFC module: 45 단계, 이미지 1/1
    • under the shield
  46. Nikon 1 J5 Teardown (repair purpose), More pics: 46 단계, 이미지 1/2 Nikon 1 J5 Teardown (repair purpose), More pics: 46 단계, 이미지 2/2
  47. Nikon 1 J5 Teardown (repair purpose), More pics: 47 단계, 이미지 1/1
Terrance
회원 가입일: 11/17/09
6,368 평판
안내서 17개 작성하였습니다
댓글 12개
Hi Terrance - the return spring on the on/off switch has gone on mine - are you able to see how to get at this on your stripped down one?
freecycle at evendine dot eclipse dot co dot uk in case I don’t notice it coming up here
chris morton - 답글
hmm, haven’t dug that deep yet… The front case disassembly seems very tricky. Also the IR-cut removal.
Terrance -
Sorry to hear that, I arrive here coming for a solution for the return spring on the on/off switch, is not a big problem but a pain and battery drain if you don’t realise :)
Anyway thanks for your teardown really formative.
juan valderrabano - 답글
I tried to remove the top cover to repair the return spring on the ON/OFF, but I was not able to separate it from the body. I have no solution.
Jacques Guyon - 답글
I finally got my hands on a wasted 1J5 and go on with the tear down. FYI top cover is sort of easy to remove, but very tricky. post more photos later.
I some simple words, after removing main PCB, remove some screws from left-upper right-upper and inside flash bay,you can wiggle the top clean off.
And, the power switch is berried very deep. you have to fond all sneaky screws. Aaaaaand the mode dial cap is double-side-taped, some thermal energy needed.
Terrance -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 167
전체 시간: 3,196
