주요 콘텐츠로 건너뛰기
해당 분해도에 사용된 도구
해당 분해도는 수리 안내서가 아닙니다. Nikon 1 J5 수리는 저희 서비스 설명서를 사용하십시오.
  1. Remove Lens, MicroSD Card and Battery Remove Lens, MicroSD Card and Battery
    • Remove Lens, MicroSD Card and Battery
  2. Remove 2 screws first Lift the cover Disconnect LCD FPC
    • Remove 2 screws first
    • Lift the cover
    • Disconnect LCD FPC
    • Then remove 4 screws
    • Remove LCD assembly
  3. Insert wisdom here. Insert wisdom here.
    • Insert wisdom here.
  4. Remove 2 screws
    • Remove 2 screws
  5. Open connection bay
    • Open connection bay
    • Remove 2 screws
  6. Remove 1 screw under the DC power cable notch cover
    • Remove 1 screw under the DC power cable notch cover
  7. Remove 4 screws and be ware the length difference Peel the rubber open from right hand side Remove 1 screw
    • Remove 4 screws and be ware the length difference
    • Peel the rubber open from right hand side
    • Remove 1 screw
  8. Now the back case can be removed. There's no fragile FPC or cables in this step. Just be patient.
    • Now the back case can be removed.
    • There's no fragile FPC or cables in this step. Just be patient.
  9. Disconnect speaker cable Pull out keypad cable Pull out keypad cable
    • Disconnect speaker cable
    • Pull out keypad cable
  10. Insert small crowbar or flat head screw driver here to lift the keypad up. Those clips are very tight.
    • Insert small crowbar or flat head screw driver here to lift the keypad up.
    • Those clips are very tight.
  11. Remove 3 screws Remove 2 screws Notice the sizes of screws
    • Remove 3 screws
    • Remove 2 screws
    • Notice the sizes of screws
  12. Need some tape peeling
    • Need some tape peeling
  13. Dangerous DC Voltage > 200V, stored in a 330V 80uF capacitor set.
    • Dangerous DC Voltage > 200V, stored in a 330V 80uF capacitor set.
    • Flash xenon tube terminals, positive connected to capacitor, negative controlled by circuit, and a trigger signal.
    • Use 10kohm, >2W resistor, connect 2 solder joints for more than 5sec. These are flash condenser/capacitor terminals. DO NOT discharge by SHORT them. (Note 2020-10-13)
    • DMM's Low-Z voltage works even better, also safer.
    • Measure voltage between 2 solder joints to ensure voltage <10V
  14. Flash solenoid and detect
    • Flash solenoid and detect
    • Microphones and AF assistant LED
    • Keypad
    • Switches
    • NFC
    • WiFi and Bluetooth, Lens(back)
    • CMOS sensor
    • LCD
  15. Detach every FPC you can find Detach every FPC you can find Detach every FPC you can find
    • Detach every FPC you can find
  16. Detach every FPC you can find Detach every FPC you can find Detach every FPC you can find
  17. Desolder flash condenser FPC and Flash cables (remember to discharge first) Desolder flash condenser FPC and Flash cables (remember to discharge first) Desolder flash condenser FPC and Flash cables (remember to discharge first)
    • Desolder flash condenser FPC and Flash cables (remember to discharge first)
  18. More FPC More FPC
    • More FPC
  19. Lift Main PCB, SLOWLY and GENTLY One more FPC at the back side. One more FPC at the back side.
    • Lift Main PCB, SLOWLY and GENTLY
    • One more FPC at the back side.
  20. Insert wisdom here. Insert wisdom here.
  21. Mark 3 screws for their ID and position. Also record how many turns to the limit.
    • Mark 3 screws for their ID and position.
    • Also record how many turns to the limit.
    • Measure and record distance to front flange if possible.
    • These screws will affect focus focal plain.
  22. Sensor module and IR-cut filter Sensor module and IR-cut filter Sensor module and IR-cut filter
    • Sensor module and IR-cut filter
  23. Insert wisdom here. Insert wisdom here. Insert wisdom here.
  24. And I don't quite remember what is this filter/window. And I don't quite remember what is this filter/window. And I don't quite remember what is this filter/window.
    • And I don't quite remember what is this filter/window.
  25. remove 2 self tap screws (upper and lower) Sorry for the magical color change of victim camera and chaotic white balance on of my desk(mixed warm LED and flash). Sorry for the magical color change of victim camera and chaotic white balance on of my desk(mixed warm LED and flash).
    • remove 2 self tap screws (upper and lower)
    • Sorry for the magical color change of victim camera and chaotic white balance on of my desk(mixed warm LED and flash).
  26. Insert wisdom here. Insert wisdom here. Insert wisdom here.
  27. Pop up flash by pulling up the solenoid Remove screw in flash bay
    • Pop up flash by pulling up the solenoid
    • Remove screw in flash bay
  28. Remove 2  self tap screws Remove 2  self tap screws
    • Remove 2 self tap screws
  29. Now you can wiggle off top case. Only 3 small clips
    • Now you can wiggle off top case.
    • Only 3 small clips
  30. Remove this screw Remove flash head
    • Remove this screw
    • Remove flash head
  31. Top Case AF assistant LED and left Microphone Switch board. Right microphone, power switch, shutter button, mode dial, main command dial.
    • Top Case
    • AF assistant LED and left Microphone
    • Switch board. Right microphone, power switch, shutter button, mode dial, main command dial.
  32. screws FPC Sneaky screw
    • screws
    • FPC
    • Sneaky screw
  33. Mode dial cap is double sided taped, Remove switch board.
    • Mode dial cap is double sided taped,
    • Remove switch board.
    • Someone else already murdered the main dial and video record button...
  34. Light guide other angles other angles
    • Light guide
    • other angles
  35. Sneakier screw Sneakier screw Sneakier screw
    • Sneakier screw
  36. sc...s sc...s sc...s
    • sc...s
  37. Focus adjust and focal plane calibration is important to par-focal lenses
    • Focus adjust and focal plane calibration is important to par-focal lenses
  38. Insert wisdom here. Insert wisdom here. Insert wisdom here.
  39. and lens contacts and lens contacts and lens contacts
    • and lens contacts
  40. Insert wisdom here. Insert wisdom here.
  41. Insert wisdom here. Insert wisdom here. Insert wisdom here.
  42. Capacitor / condenser, which do you prefer? Capacitor / condenser, which do you prefer?
    • Capacitor / condenser, which do you prefer?
  43. WiFi and bluetooth Lens latch pin Lens latch pin
    • WiFi and bluetooth
    • Lens latch pin
  44. This one is liquid damaged This one is liquid damaged
    • This one is liquid damaged
  45. under the shield
    • under the shield
  46. Insert wisdom here. Insert wisdom here.
  47. Insert wisdom here.
Terrance
회원 가입일: 2009년 11월 17일
5,164 평판
안내서 10개 작성하였습니다
댓글 9개
Hi Terrance - the return spring on the on/off switch has gone on mine - are you able to see how to get at this on your stripped down one?
freecycle at evendine dot eclipse dot co dot uk in case I don’t notice it coming up here
chris morton - 답글
hmm, haven’t dug that deep yet… The front case disassembly seems very tricky. Also the IR-cut removal.
Terrance -
Sorry to hear that, I arrive here coming for a solution for the return spring on the on/off switch, is not a big problem but a pain and battery drain if you don’t realise :)
Anyway thanks for your teardown really formative.
juan valderrabano - 답글
I tried to remove the top cover to repair the return spring on the ON/OFF, but I was not able to separate it from the body. I have no solution.
Jacques Guyon - 답글
I finally got my hands on a wasted 1J5 and go on with the tear down. FYI top cover is sort of easy to remove, but very tricky. post more photos later.
I some simple words, after removing main PCB, remove some screws from left-upper right-upper and inside flash bay,you can wiggle the top clean off.
And, the power switch is berried very deep. you have to fond all sneaky screws. Aaaaaand the mode dial cap is double-side-taped, some thermal energy needed.
Terrance -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 35
전체 시간: 1,560
