In this tutorial we will show you a breakdown of the Panazonic EB TX320. By using this guide, a user will be able to properly take apart their phone and replace any broken components.
해당 분해도는 수리 안내서가 아닙니다 . Panasonic EB TX320ASW 수리는 자사의 서비스 설명서 를 사용하세요.
To remove keypad, turn front of phone over and let keypad fall out. All keys are connected by one rubber section.
If a button had been ripped off your keypad, you can replace the entire rubber keypad at this step and reassemble phone.
After silver plate is removed, power button sits freely. Speaker can be removed by pulling up on it.
If your speaker went out it can easily be replaced in this step with a new one, then reassemble phone after this step.
To remove LCD screen pry back on highlighted clip and pull screen out. The screen will then pull up and out.
If the LCD screen went out, or was cracked somehow, replace with a new LCD screen and then reassemble phone from this step.
해당 안내서 넣기
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
단일 단계
전체 안내서
소형 - 600px
중형 - 800px
대형 - 1200px
미리보기
