주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Retina MacBook 2016 수리는 저희 서비스 설명서를 사용하십시오.
  1. Retina MacBook 2016 Teardown, Retina MacBook 2016 Teardown: 1 단계, 이미지 1/2 Retina MacBook 2016 Teardown, Retina MacBook 2016 Teardown: 1 단계, 이미지 2/2
    • With the MacBook jumping on the Rose Gold bandwagon, who knows what's lurking inside? Here's the lowdown so far:
    • 12-inch 2304 × 1440 (226 ppi) IPS Retina Display
    • 1.1 GHz dual-core Intel Core m3 processor (configurable up to 1.3 GHz dual-core Intel Core m7)
    • 8 GB of 1866 MHz LPDDR3 RAM
    • 256 or 512 GB PCIe-based flash storage
    • Intel HD Graphics 515
    • 802.11a/b/g/n/ac Wi-Fi wireless networking and Bluetooth 4.0
    • Single USB-C port and 3.5 mm headphone jack
  2. Retina MacBook 2016 Teardown: 2 단계, 이미지 1/2 Retina MacBook 2016 Teardown: 2 단계, 이미지 2/2
    • If it weren't for the rose gold finish, we'd be hard-pressed to distinguish between this year's Retina MacBook, and the one of yesteryear.
    • The exteriors look identical, from the Pentalobe screws in the lower case all the way down to the model number—A1534.
    • The only telltale sign that something's different is the updated EMC number: 2991 compared to last year's 2746.
  3. Retina MacBook 2016 Teardown: 3 단계, 이미지 1/2 Retina MacBook 2016 Teardown: 3 단계, 이미지 2/2
    • Popping the hood on this MacBook gives us an indication that the rose gold beauty is much more than skin deep.
    • Before delving any deeper into this beauty, we take a quick look at the chips powering the trackpad:
    • Broadcom BCM5976 touchscreen controller
    • STMicroelectronics STM32F103 32-bit ARM Cortex-M3 microcontroller
    • Monolithic Power Systems MP24830HL White LED driver and International Rectifier IRFH3702 power MOSFET
    • Maxim Integrated MAX11290 analog-to-digital converter (likely)
    • Macronix MX25L2006EZUI-12G 2 Mb Serial NOR flash memory
    • Maxim Integrated MAX9028 comparator
  4. Retina MacBook 2016 Teardown: 4 단계, 이미지 1/1
    • Touchpad sensors:
    • Bosch Sensortec BMA282 accelerometer
    • Texas Instruments TMP421 temperature sensor
  5. Retina MacBook 2016 Teardown: 5 단계, 이미지 1/3 Retina MacBook 2016 Teardown: 5 단계, 이미지 2/3 Retina MacBook 2016 Teardown: 5 단계, 이미지 3/3
    • What's that? The pesky tri-wing screw we saw last year grew another, um, wing—now it's a regular ol' repair-friendly Phillips.
    • If you weren't put off by the Pentalobes on the lower case, then a tri-wing probably won't slow you down much—but hey, we'll take what we can get!
    • Thankfully, all the other internal screws remain standard Phillips and Torx screws.
    • However, another surprise awaits at the hinge screws, whose Torx heads are filled with some sort of substance that disintegrates when you insert a screwdriver. Are you sealing our MacBook with tamper-evident screws, Apple?
    The "Blue" stuff is Loctite and has nothing to do with "Anti-Tamper"-Measuremts.
    What sort of experts are you? ;)
    Matthis - 답글
    I promise you, we're not talking about the blue stuff. We know what threadlocker is. ;) The substance we're referring to fills the screw heads, not the threads. Have another read and take a closer look at the head of the removed screw vs. the installed one.
    Jeff Suovanen -
    as a former tech, I doubt they have the capacity to look out for that.
    YourMomsAndMe - 답글
    Apple is likely using a corrosion sealer and in this case the sealer created a bubble in the hollow.
    Dan - 답글
  6. Retina MacBook 2016 Teardown: 6 단계, 이미지 1/2 Retina MacBook 2016 Teardown: 6 단계, 이미지 2/2
    • And at the other end of the MacBook, it seems the USB-C hardware has also changed. The cable is now perma-fixed to the USB board, condensing the two components into a single unit.
    • ...Also, the silicon is new and moved from the cable itself to the USB board. Here's a comparison of the new USB-C hardware (top) with that of the 2015 Retina MacBook (bottom).
    • Parade Technologies PS8741A (likely an iteration of the PS8740 USB-C redriving switch)
    • Diodes Incorporated PI1EQX7502 USB 3.0 redriver (likely)
    • NXP Semiconductor CBTL04043A1 4-Ch. bidirectional crossbar switch
    • This new USB and cable arrangement is one thing that's not compatible with previous Retina MacBooks.
    Any color on whether Apple redesigned the USB connector/cable such that it could be removed without having to remove the hinge? (In last year's model, the USB "module" is held captive by the hinge flange.) Esp in light of those tamper-resistant hinge screws.
    Scott - 답글
    The redesign doesn't seem to have made the USB board any easier to remove.
    Jeff Suovanen -
    Not tamper-resistant - tamper evident.
    And that's a good point - hinge screws should be tamper evident because a loose or wobbly hinge puts strong forces where they shouldn't go and it's possible to damage a chassis and internal boards if they are not torqued correctly Screen hinges are subject to a lot of forces through use and abuse, and while they are strong, the get that strength when properly attached. Do it wrong and you'll put stresses where they weren't designed to be, which can be a cracked or bent case at the best, bent or cracked circuit boards or screen at the worst. So Apple puts it there to see if you've been fiddling with the hinge and possibly caused damage not covered by the warranty.
    Worf - 답글
    can the USB-C port be replaced when it wears out/fail?
    Mike Liang - 답글
    Hey any body know where I can find the USB C flex for the 2016 MacBook retina even used would be ok
    Sam Garesche - 답글
    Is the 2016 connector compatible with the 2015 connector? The Logicboard part seems to be the same. Does anyone knows about that?
    Martin Kühn - 답글
    For anyone wondering, no, you CANNOT install the 2015 flex cable in the 2016 Macbook, and vice-versa. While they look very similar in the pictures, the motherboard connection is actually slightly smaller on the 2016 model.
    Really sucks as the 2015 flex cable can be had online for ~$40, while the 2016 flex cable is easily around $100.
    Unfortunately a terribly designed computer in many respects…
    Dillon Dixon - 답글
  7. Retina MacBook 2016 Teardown: 7 단계, 이미지 1/2 Retina MacBook 2016 Teardown: 7 단계, 이미지 2/2
    • The battery's form factor seems 100% identical to the multi-lobed cell we found in the 2015 Macbook.
    • And yet somehow, Apple managed to squeeze in a 4% capacity increase from the 7.55 V, 39.71 Wh battery in last year's model. Apple claims this new 7.56 V, 41.41 Wh Li-ion power source should provide up to 11 hours of iTunes movie playback.
    • We're guessing this capacity increase is owed to improved battery chemistry (though it's also possible that Apple's engineers have shaved away just enough material from the lower case to allow for a thicker battery).
    • Unfortunately, they did not squeeze in any of those nifty adhesive pull tabs we've seen in Apple's iDevices.
    • Regardless, our tests indicate this beefier battery is compatible with last year's MacBook. Nice!
    What are the "edge-shaped" cutouts on the lower corners of the upper two cells in the picture? Maybe needed for ventilation to work, or to ensure the book doesn't "flex" (or worse, squeeze the batteries too much, ending up with the Note 7 we all know and love..)
    jimwitte - 답글
  8. Retina MacBook 2016 Teardown: 8 단계, 이미지 1/1
    • Logic Board! What chips is this MacBook serving up?
    • Intel SR2EN Intel Core m3-6Y30 Processor (4M Cache, up to 2.20 GHz)
    • Toshiba TH58TFT0DFKLAVF 128 GB MLC NAND Flash (+ 128 GB on the reverse side for a total of 256 GB)
    • Micron MT41K256M16LY-107:N 512 Mb DDR3L SDRAM memory
    • Universal Scientific Industrial 339S0250 Wi-Fi module
    • Broadcom BCM15700A2 (as seen in several other MacBook models) webcam controller (likely)
    • National Semiconductor 48B1-11 (LP8548B1) backlight driver
    • Micron EDF4432ACPE-GD-F 4 GB LPDDR3 SDRAM Memory (with SSD controller presumably layered underneath)
    Will you disassemble F4432ACPE-GD-F to check if there is a "NEW" SSD controller under it? From the marking, the memory is probably LPDDR3 memory from Micron/Elpida. Perhaps, Apple has new NVMe SSD controller for Macbook 2016.
    JJ Wu - 답글
    Please refer to http://abtronics.kz/components/EDF4432AC...
    There is 4Gb LPDDR3 from Micron/Elpida. The part number is "EDF4432ACPE-GD-F-R" that is similar to "F4432ACPE-GD-F" in the Macbook 2016. If it is LPDDR3 truly, probably the NVMe SSD controller in the Macbook 2016 is different from the one used in the Macbook 2015. The memory NVMe SSD controller used in the Macbook 2015 is 4Gb LPDDR2.
    JJ Wu - 답글
    Agree with you, there should a new SSD controller for Macboo 2016. Can theifixit de-PoP the memory and controller for Macbook 2016 as you did fro Macbook 2015?
    CM YANG -
    Would the early 2016 logic board be compatible with the 2015 MacBook? E.g. Can you put the 2016 logic board in the old 2015?
    James - 답글
    Does the retina MacBook have 2x2 or 3x3 antennae?
    David Ahn - 답글
  9. Retina MacBook 2016 Teardown: 9 단계, 이미지 1/1
    • But wait, there's even more chips on the back:
    • Toshiba TH58TFT0DFKLAVF 128 GB MLC NAND flash memory
    • Samsung K3QF4F40BM-AGCF 4 GB LPDDR3 SDRAM (x2, for a total of 8 GB)
    • Apple 338S00066 power management IC
    • Texas Instruments/Stellaris LM4FS1EH SMC controller (replacement codename for TM4EA231)
    • Microchip (formerly SMSC) EMC1704-2 temperature sensor
    • Texas Instruments SN650839 step down DC-DC converter (likely), TPS51980A PMIC, and CD3215B01 USB-C controller
    • Intersil ISL95828 Intel CPU PWM controller
    Can someone tell me where the Power Pins are? Are they these two bits between the battery and keyboard connector?
    Does anyone have the exact size/data of it? I would like to render it…
    Yuna Braska - 답글
  10. Retina MacBook 2016 Teardown: 10 단계, 이미지 1/2 Retina MacBook 2016 Teardown: 10 단계, 이미지 2/2
    • IC identification, continued:
    • Renesas ISL95530 battery charger
    • Vishay SiC535 power stage
    • Maxim Integrated MAX98357B audio amplifier
    • Texas Instruments TMP102 temperature sensor
    • Microchip (formerly Atmel) AT93C66B 4 K serial EEPROM memory
    • Macronix MX25L2006EZUI-12G 2 Mb flash memory
    • Texas Instruments INA211 and INA214 current sense amplifier
  11. Retina MacBook 2016 Teardown: 11 단계, 이미지 1/2 Retina MacBook 2016 Teardown: 11 단계, 이미지 2/2
    • Retina Macbook 2016 Repairability Score: 1 out of 10 (10 is the easiest to repair)
    • Those pesky tri-wing screws are gone, replaced with lovely standard Phillips screws—but tamper-evident hinge screws make you feel like a hoodlum for repairing your own machine.
    • The processor, RAM, and flash memory are still soldered to the logic board.
    • The battery assembly remains entirely, and very solidly, glued into the lower case.
    • The Retina display is still a fused unit with no separate, protective glass. If the display needs replacing, it'll cost a pretty penny.
    • While it's no more repairable than last year's edition, it does benefit from sharing a lot of the same parts and repair procedures.
Evan Noronha
회원 가입일: 02/05/15
223,469 평판
안내서 168개 작성하였습니다
댓글 50개
Step 8, Apple 338S00066 should not be the SSD controller. It might be the audio codec.
Step7, The SSD controller should be under the chip "F4432ACPE-GD-F".
JJ Wu - 답글
It's been reported that the new Apple designed SSD controller sits next to the NAND flash chip instead of under it.
eric.summers -
Yes. Apple designed SSD controller is next to the NAND flash chip as Step 7 shown. F4432ACPE-GD-F chip is next to Toshiba NAND Flash chip. SSD controller needs memory. In 2015 model, Apple uses PoP package to put it upon the SSD controller.
Retina MacBook 2015 Teardown Step 14
JJ Wu -
So how much RAM in total does it have? 4GB Micron (Micron MT41K256M16LY-107 4Gb DDR3L SDRAM) plus 8GB Samsung (Samsung K3QF4F4 4 GB LPDDR3 RAM (x2, for a total of 8 GB)) ?
JA VE - 답글
4Gb -> 512MB, more likely for SSD cache
mesish -
Micron 4Gb DDR3L is the memory for Broadcom BCM15700A2. Total system memory is 8GB which are two Samsung K3QF4F4 4GB LPDDR3 RAM.
JJ Wu -
It would be nice to have some more information about the camera Apple uses. The rumor mill has some conjecture that they stuck with a 480p camera because there aren't any higher resolution cameras that would fit into the display without making it thicker.
Paul L - 답글
Total system memory is 8GB as the information shown on Apple web site. There are two LPDDR3-1866 from SAMSUNG which is shown on Step 8. The chip is marked in orange color. The part number is K3QF4F40BMAGCF. Most likely, it is customized package for Apple. (It was Elpida/Micron in 2015 model.) Micron MT41K256M16LY-107 4Gb DDR3L SDRAM is for Broadcom BCM15700A2.(It was Micron in 2015 model.) The memory for SSD controller should be F4432ACPE-GD-F shown on step 7. The SSD controller is under "F4432ACPE-GD-F". In 2015 model, it showed the SSD controller uses Apple customized PoP package.
JJ Wu -
indeed. any idea about the camera ? is it still 480P ?
Ilias Leontiadis -
SSD as RAID 0? That is the best way to lose data if one of the disks fails or the controller:
Toshiba TH58TFT0DFKLAVF 128 GB MLC NAND Flash (+ 128 GB on the reverse side for a total of 256 GB).
Peter Gamble - 답글
this is how ssd are built - almost every ssd on this planet is built from discrete chips internally connected into something you could call raid 60 (but its quite different mumbo jumbo, as there is wear levelling, still concept is very similar)
amadeuszleonardo -
I still believe that it is RAID 0 because of the two modules and because of 2x speeds than current Toshiba flash. Much as this from SanDisk :
SanDisk Extreme 900 portable SSD https://www.sandisk.com/home/ssd/extreme...
The read and write specifications of those drives are twice than the Toshiba flash offerings, which points to RAID 0. That is why I asked, in case someone has more real specific information.
Peter Gamble -
Here is a shocking (RAID) example:
OWC’s Aura SSDs are a good way to add storage to newer MacBooks, with caveats
From a hardware perspective, the 1TB Aura drive is actually two SSD controllers RAIDed together with a Marvell 9230 RAID controller.
http://arstechnica.com/apple/2016/04/owc...
Peter Gamble -
"Torx heads are filled with some sort of substance that disintegrates when you insert a screwdriver. "
That sounds to me like "Torque-Seal" or similar products found here: http://www.opcompany.com/
It's a thick liquid, similar in viscosity to toothpaste, that dries to a hard, but very brittle material. It's commonly used in aerospace applications. Typical application is to apply it in a stripe across a nut or screw head and onto the adjacent surface. Any slight rotation of the fastener causes the brittle material to break apart. It's used to spot evidence of loose fasteners due to vibration or damage. It's also used by repair centers to certify their work has not been tampered with. The latter use is similar to the stickers that read "Void If Removed" when peeled off.
voiceofreasonver2 - 답글
Organic Products Company is now ITW ProBrands
http://itwprofessionalbrands.com/dymon-p...
ciradrak -
That's not tamper evident stuff, it's thread locking adhesive!
http://www.loctite.co.uk/loctite-4087.ht...
It's to stop the screws vibrating loose.
jim - 답글
We're referring to the substance filling the screw heads, not the blue threadlocker on the threads. Look at the head of the screw that's been removed, and compare it with the other one that's still in place.
Jeff Suovanen -
Tamper evident screws by simply pushing anything into the screw head? Sure that wont stand up to any questions Apple may put to you, did you open it? No. But the substance in the screw heads has been pushed out. Oh really? Is that on the outside of a case that anyone walking by can puch a pinhead into and scrape it out? Yes...
Wouldnt hold up to any no-warranty claims by apple in my country, try excluding your warranty based on a small substance on a screw head, even the warranty void external labels dont stand up to legal exclusions to warranty claims as they can easily be scratched or removed from an external device with nothing else done.
Hamish Robinson - 답글
Wow your country is so cool, Hamish.
mosburger -
So it's harder to replace components and fix the thing then iPad , iPod touch or cheap chinese PC that's glued together using components that no one can get anywhere ?
I don't really get your scoring tactics - ifixit people...
gg0d - 답글
The Logic Board in 2016 model looks more beautiful than that of 2015 model. The electronic components are arranged much more neatly on this new board. But Apple uses smaller electronic components this time, which I think should be cheaper. So what do you think about the Electrical Performance of the new and old Logic Board?
Joc May - 답글
What size is the trackpad? Is it the same size as the 15" MacBook Pro?
lyallm123 - 답글
More information:
Meanwhile, the PCIe SSD inside now reaches average write speeds of 845 MB/s, according to the Blackmagic Disk Speed Test. That's way up from 451.7 MB/s on last year's model, which was already more than what we see on many flagship laptops. Meanwhile, read speeds are now approaching a gigabyte per second, with the rates in my tests coming out to an average of 947 MB/s. That's up considerably from 738.2 MB/s last year.
Source: Apple's updated MacBook is indeed faster with longer battery life
http://www.engadget.com/2016/04/25/apple...
And here is more revealing information: latest Toshiba catalog (March 2016) does not have such SSD with 947MB/s read and 845MB/s write:
http://toshiba.semicon-storage.com/info/...
So, again, all that points to RAID 0 in Toshiba SSD inside MacBook.
Peter Gamble - 답글
The SSD inside Macbook is not Toshiba solution. The SSD controller is Apple proprietary NVMe SSD solution. The Toshiba part is 128GB MLC NAND Flash. In Macbook 2015, SSD controller uses 4-lanes PCIe 2.0 interface. But, in MacBook 2016, the SSD controller is 2-lanes PCIe 3.0.
JJ Wu -
Yes! that's good for repairing hardware parts,
How to solve if the system or operating system are not working.
What the possible solution we need.
please help me.
Rjames Tabuzo - 답글
This is a hardware repair site
bluesix -
The LCD screen CAN BE separated from the housing. As the macbook pro retina.
It cost less than change the whole LCD assembly with Facetime, antennas ... Aluminium cover
Alexandre Galeotti - 답글
so Ray serves the chipset BCM15700A2
Leonel Tirado - 답글
so ray serves the Chipset BCM15700A2
Leonel Tirado - 답글
Hi,
do you know where the humidity sensors are located?
Thank you in advance.
Hans - 답글
So my 2015 logic board is fried and was wondering if one could put in a 2016 logic board (I guess with the new USB-C cable since that changed)? At least get an upgrade when repairing this princess machine that couldn't handle 20 rain drops while in a bag (assuming I can find a '16 LB and cable used).
aknabi - 답글
Is each size of SSD in the latest macbook the same model? That is, the speed of the 2TB SSD the same as the speed of the 512GB one?
Wayner - 답글
Thank you for this tutorial, it is very helpful. Unfortunately, I need a laptop with 16GB RAM for memory intensive tasks, and this laptop has no option to upgrade, which means I need to look somewhere else. Thanks again.
Andy Leung - 답글
are the keyboard and the trackpad molded into the upper case?
Sacha Pewzer - 답글
Cant be upgraded at all, slower then previous MacBook, worse battery life, lack of ports, expensive, and removed of magsafe. So can you tell me why its worth it?
sam errett - 답글
It's Rose Gold. The review says nothing about it being slower or having worse battery life.
mosburger -
Is it possible to replace the keyboard on these models like older ones, if water gets on it for instance?
tipoo - 답글
Hello friends!
Need this CD3215b01.
iobukhovich@gmail.com
Ilya - 답글
Does anyone know if this SSD bypass hardware copy tool is available anywhere?
http://www.mactrast.com/2016/11/apple-ss...
Somewhere near Japan would be preferable for my situation.
Madhava Jay - 답글
Random Question here, but is it possible to install the, let's say, 2016 logic board into a 2015 MacBook body? has anyone tried it or thought about this before?
Elve Acevedo - 답글
Hi Elve! Although I have never tried to put a 2016 Retina Macbook logic board into a Retina Macbook from 2015, I imagine it will not work. Usually the chipset on the logic board is very specific for the periphery hardware (i.e. daughter boards and components). The logic board is also usually coupled with specific firmware that couples with the chips and components of the year it was built for, and will probably not behave properly when put into a "new home". This all being said, there is only one real way to find out! You should let us know if you give it a try.
Scott Havard -
Appeal to the iFixit gods: I disconnected the Touchpad cable because it had stopped working. I reconnected it but now the keyboard stopped working AND the display works only intermittently. How hard have I f*cked myself and can I fix this by buying a replacement flex cable? Is there a more detailed repair guide on that anywhere? Thanks in advance!
Chris - 답글
Following up on this repair: I bought a new trackpad unit and everything works perfectly again.
Chris -
Anyone ever attempted a battery replacement on this? I know iFixit says there’s super strong adhesive but if it’s similar to the strong adhesive on the iPhone battery, then it just seems like the same process but 5 times.
Chris - 답글
First my keyboard got broken on my A1514 Early 2016. I was managing somehow to work with broken space and backspace. Then the recall came - a couple of months later and I was relived from this pain…. and a couple weeks later the mother board failed. So basically, I am hoping now for a new recall - there are tons of failed and working boards on ebay and aliexpress so I assume it is something that many people face.
zahariev_a - 답글
why do not have the top down view of the internal components
Xi Haw Kong - 답글
can I put a 2016 logic card in a 2015?
alejandro avalos - 답글
Hey, my macbook doesn’t recognise the startup disk so it can’t load. any chance i could change the flash storage? if no then what should i do?
Timotius Satrio - 답글
hey man, i have the same problem now. did you ever figure this out? would love any advice
Tyler Blake -
댓글 쓰기
조회 통계:
24 시간 전: 18
7일 전: 124
30일 전: 487
전체 시간: 219,203
