소개
Here is a relatively inexpensive and small guitar amp. This particular one needed some repair. So while I was waiting for parts, I figured I might as well make a teardown.
필요한 것
Here is the front view of the Rogue G10 amp.
Back side shows 4 Phillips head screws that need to be removed.
Here are the 4 #6x1" screws
This shows the corners with the screws removed.
Remove the rubber feet by removing the Phillips head screws.
On the left and right side of the amp is a Phillips head screw, located 1/3 down from the top and to the front. These two screws hold the front panel to which the speaker is attached. Remove those.
댓글 4개
Do these models have tubes in them?
No, they do not. Strictly solid state
Thank you so much
