주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Rogue G10 수리는 저희 서비스 설명서를 사용하십시오.
  1. Rogue G10 Teardown, Rogue G10 Teardown: 1 단계, 이미지 1/3 Rogue G10 Teardown, Rogue G10 Teardown: 1 단계, 이미지 2/3 Rogue G10 Teardown, Rogue G10 Teardown: 1 단계, 이미지 3/3
    • Here is the front view of the Rogue G10 amp.
    • Back side shows 4 Phillips head screws that need to be removed.
    • Here are the 4 #6x1" screws
  2. Rogue G10 Teardown: 2 단계, 이미지 1/3 Rogue G10 Teardown: 2 단계, 이미지 2/3 Rogue G10 Teardown: 2 단계, 이미지 3/3
    • Use a small screwdriver or other small suitable prying instrument to remove the back cover.
    • With the back cover removed the speaker and amp become visible.
    • Remove the 2 Phillips head screws from the carrying handle. These two screws also attach the amp to the onside of the case.
  3. Rogue G10 Teardown: 3 단계, 이미지 1/3 Rogue G10 Teardown: 3 단계, 이미지 2/3 Rogue G10 Teardown: 3 단계, 이미지 3/3
    • Here are the two screws from the handle. They are 1/8"x1 1/4"
    • Remove the 16 screws from the plastic corners. These corners serve no purpose other than decoration.
    • There are 4 rubber feet on the bottom of the amp.
  4. Rogue G10 Teardown: 4 단계, 이미지 1/3 Rogue G10 Teardown: 4 단계, 이미지 2/3 Rogue G10 Teardown: 4 단계, 이미지 3/3
    • This shows the corners with the screws removed.
    • Remove the rubber feet by removing the Phillips head screws.
    • On the left and right side of the amp is a Phillips head screw, located 1/3 down from the top and to the front. These two screws hold the front panel to which the speaker is attached. Remove those.
  5. Rogue G10 Teardown: 5 단계, 이미지 1/3 Rogue G10 Teardown: 5 단계, 이미지 2/3 Rogue G10 Teardown: 5 단계, 이미지 3/3
    • Here is the one on the right side, same location.
    • Remove it as well
    • With those two screws removed, the front panel which houses the speaker, can be simply removed
  6. Rogue G10 Teardown: 6 단계, 이미지 1/3 Rogue G10 Teardown: 6 단계, 이미지 2/3 Rogue G10 Teardown: 6 단계, 이미지 3/3
    • remove the front panel and place aside.
    • With the front panel removed, the amp will now simply lift out as well
    • Here is the amp totally disassembled. Straight forward job. No glue, no hidden screws.
oldturkey03
회원 가입일: 09/29/10
782,439 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
33 회원들
안내서 544개 작성하였습니다
댓글 4개
Do these models have tubes in them?
Camron Buxton - 답글
No, they do not. Strictly solid state
oldturkey03 -
What may be causing the scratchy sound only when playing on my G10? Tried multiple cables and cleaned the input with electrical contact cleaner and there was no change. If I run a cable from the Phones jack to my computer input then the noise is not there.
Brian Day - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 3,121
