주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Rubik's Cube 수리는 저희 서비스 설명서를 사용하십시오.
  1. Rubik's Cube Teardown, Rubik's Cube Teardown: 1 단계, 이미지 1/3 Rubik's Cube Teardown, Rubik's Cube Teardown: 1 단계, 이미지 2/3 Rubik's Cube Teardown, Rubik's Cube Teardown: 1 단계, 이미지 3/3
    • Turn the top row so that each corner is roughly halfway between the sides
    • Push the pieces up until they pop out of the cube, then, slide the rest out
    • Repeat this process until you clear the level
  2. Rubik's Cube Teardown: 2 단계, 이미지 1/2 Rubik's Cube Teardown: 2 단계, 이미지 2/2
    • You should be able to just directly pull out the rest of the blocks, like so
    • And there you have it!
    • You'll have the center piece, with the six centers of the six sides, the turning mechanism
  3. Rubik's Cube Teardown: 3 단계, 이미지 1/2 Rubik's Cube Teardown: 3 단계, 이미지 2/2
    • To reassemble, snap all the pieces back into place, and try not to rotate the faces.
    • It helps to start with the middle pieces first
    • Don't be afraid to use force!
    • Once you have the middle pieces in it's pretty simple to just push in the corner pieces
    • Again- don't be afraid to use force!
    Rubik’s Cube BROKEN using this method on a cube with a Circular Center. Last corner piece snapped when pushing in. Not recommended to use ‘force’ as the little plastic pieces can’t withstand it.
    * This method only works if you have a Rubik’s Cube that looks exactly like the one in the video when disassembled! If your Rubik’s Cube looks different (circular center) DO NOT USE THIS METHOD!!!!!
    Booya Tribe - 답글
rab777hp
회원 가입일: 11/17/09
20,333 평판
안내서 3개 작성하였습니다
OPEN OPEN 회원
Community
82 회원들
안내서 25개 작성하였습니다
댓글 6개
I hated this thing. I disassembled mine with a .22 hollow point at 100 yards. Yes, It felt great!
mpias - 답글
lol don’t blame you, can’t stand the thing
Luke -
that method just broke my rubiks my cube.. thanks anyway
hamzamagdy888 - 답글
my middle peices came out cant fix it
jax - 답글
can someone tell me how to fix it
jax - 답글
grr i am mad that i cannot fix my rubik’s cube!
Devin Plante - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 28
전체 시간: 24,546
