주요 콘텐츠로 건너뛰기
SYNOLOGY DS718+ Teardown
  1. SYNOLOGY DS718+ Teardown, Case presentation:  front panel: 1 단계, 이미지 1/1
    • This NAS DS718 + is equipped with 4 GB of RAM (6 GB max.), an INTEL Celeron J3455 64-bit Quad processor, two bays for SATA drives (HDD, or SSD).
    • FRONT PANEL : you can notice on the right side, disks LEDs disapeared. You can find them now just on the top of the disk bays.
    • status LEDs
    • power buton (startup / shutdown)
    • 1 x USB 3 port
    • "copy" buton
    • 2 x disk support (caddy / cage)
    • disk bay lock
  2. SYNOLOGY DS718+ Teardown, Cas presentation: rear panel: 2 단계, 이미지 1/1
    • REAR PANEL
    • 1 x 92mm fan
    • 2 x EHTERNET RJ45 Gigabit port
    • 2 x USB 3 port
    • 1 x eSATA port
    • 1 x power connector
    • 1 x Kensington security incision (K-lock)
    • RESET buton
  3. SYNOLOGY DS718+ Teardown, Backplane and memory access: 3 단계, 이미지 1/3 SYNOLOGY DS718+ Teardown, Backplane and memory access: 3 단계, 이미지 2/3 SYNOLOGY DS718+ Teardown, Backplane and memory access: 3 단계, 이미지 3/3
    • Before teardown, unlock the disk media with the key.
    • It's a new appreciable feature, the memory slots are now directly reachable.
    • first memory slot
    • seonc memory slot (not populated)
    • The previous revision (DS716+ II) allowed this operation but a piece of metal prevent to remove memory.
  4. SYNOLOGY DS718+ Teardown, Teardown: Rear Panel - Step 1 / 3: 4 단계, 이미지 1/3 SYNOLOGY DS718+ Teardown, Teardown: Rear Panel - Step 1 / 3: 4 단계, 이미지 2/3 SYNOLOGY DS718+ Teardown, Teardown: Rear Panel - Step 1 / 3: 4 단계, 이미지 3/3
    • 1 - Remove the two screws placed under the NAS, on rear side.
    • 2 - Remove the screw placed in the middle of the rear panel.
  5. SYNOLOGY DS718+ Teardown, Teardown: rear panel - step 2 / 3: 5 단계, 이미지 1/3 SYNOLOGY DS718+ Teardown, Teardown: rear panel - step 2 / 3: 5 단계, 이미지 2/3 SYNOLOGY DS718+ Teardown, Teardown: rear panel - step 2 / 3: 5 단계, 이미지 3/3
    • To remove the rear panel …
    • slightly pull the lower part of the rear panel so that the lugs do not touch the case, then ...
    • drag the facade upwards …
    • The back cover is held by two notches into the case.
  6. SYNOLOGY DS718+ Teardown, Teardown: rear panel - step 3 / 3: 6 단계, 이미지 1/3 SYNOLOGY DS718+ Teardown, Teardown: rear panel - step 3 / 3: 6 단계, 이미지 2/3 SYNOLOGY DS718+ Teardown, Teardown: rear panel - step 3 / 3: 6 단계, 이미지 3/3
    • Once removed, remove the fan connector from the motherboard.
  7. SYNOLOGY DS718+ Teardown, Removing the Metal Housing: 7 단계, 이미지 1/3 SYNOLOGY DS718+ Teardown, Removing the Metal Housing: 7 단계, 이미지 2/3 SYNOLOGY DS718+ Teardown, Removing the Metal Housing: 7 단계, 이미지 3/3
    • Once the rear panel is removed, the housing can be removed. To do so drag the cover about 1 cm to the back of the NAS then lift the hood upwards.
  8. SYNOLOGY DS718+ Teardown, Naked case before disassembling metal housing: 8 단계, 이미지 1/3 SYNOLOGY DS718+ Teardown, Naked case before disassembling metal housing: 8 단계, 이미지 2/3 SYNOLOGY DS718+ Teardown, Naked case before disassembling metal housing: 8 단계, 이미지 3/3
    • Now remains the front to remove ...
    • Here are some photographs of the case and the internal structure + screws.
  9. SYNOLOGY DS718+ Teardown, Teradown: front panel - step 1 / 2: 9 단계, 이미지 1/3 SYNOLOGY DS718+ Teardown, Teradown: front panel - step 1 / 2: 9 단계, 이미지 2/3 SYNOLOGY DS718+ Teardown, Teradown: front panel - step 1 / 2: 9 단계, 이미지 3/3
    • Remove the two screws under the box on the front side and then ...
    • in the same way as for the rear panel, lift the hood slightly ...
  10. SYNOLOGY DS718+ Teardown, Teardown: front panel - step 2 / 2: 10 단계, 이미지 1/2 SYNOLOGY DS718+ Teardown, Teardown: front panel - step 2 / 2: 10 단계, 이미지 2/2
    • and remove the front panel …
  11. SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 1/3: 11 단계, 이미지 1/3 SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 1/3: 11 단계, 이미지 2/3 SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 1/3: 11 단계, 이미지 3/3
    • x 4 screws to remove …
    • x 2 on the right side panel
    • and x 2 on the upper part
  12. SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 2/3: 12 단계, 이미지 1/3 SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 2/3: 12 단계, 이미지 2/3 SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 2/3: 12 단계, 이미지 3/3
    • This part is delicate to assembly as to disassembly. Read full instructions carefully before handling.
    • The guidance remains relatively accurate but the connector for the LED card drives is fragile. Do not force when removing or inserting the side flange.
    • electronic card LED disks
    • riser for SATA backplane (electronic card or daughter card)
    • electronic card riser (USB and e-SATA)
  13. SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 3/3: 13 단계, 이미지 1/3 SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 3/3: 13 단계, 이미지 2/3 SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 3/3: 13 단계, 이미지 3/3
    • INSTRUCTIONS :
    • use both hands ...
    • pull gradually ...
    • everything must come without forcing!
    • Pay attention also to the metallic tape ... take it off if possible!
  14. SYNOLOGY DS718+ Teardown, Teardown: motherboard and memory: 14 단계, 이미지 1/2 SYNOLOGY DS718+ Teardown, Teardown: motherboard and memory: 14 단계, 이미지 2/2
    • motherboard (processor side)
    • memory card
    • last pictures are bad …
결론
To reassemble your device, follow the instructions in reverse order.
다른 5명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Sébastien
회원 가입일: 12/14/15
4,060 평판
안내서 6개 작성하였습니다
AEM (ANIMA EX MACHINA) AEM (ANIMA EX MACHINA) 회원
Business
1 회원
안내서 14개 작성하였습니다
댓글 4개
1 hour? I did it in 20 minutes that's teardown and reassembly!!?!
Ken Richner - 답글
PLZ read the introduction more carefully !
Sébastien -
How to replace a larger heat pipe radiator??
love3kkk - 답글
Any suggestions on Mother board update for the DS218+ & DS718+ ?
WA FOR SALE - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 33
30일 전: 138
전체 시간: 7,722
