주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Samsung Galaxy Note5 수리는 저희 서비스 설명서를 사용하십시오.
  1. Samsung Galaxy Note5 Teardown, Samsung Galaxy Note5 Teardown: 1 단계, 이미지 1/3 Samsung Galaxy Note5 Teardown, Samsung Galaxy Note5 Teardown: 1 단계, 이미지 2/3 Samsung Galaxy Note5 Teardown, Samsung Galaxy Note5 Teardown: 1 단계, 이미지 3/3
    • Remove SIM card tray at first. It's Samsung Galaxy Note 5 Duos, so there are two slots.
  2. Samsung Galaxy Note5 Teardown: 2 단계, 이미지 1/3 Samsung Galaxy Note5 Teardown: 2 단계, 이미지 2/3 Samsung Galaxy Note5 Teardown: 2 단계, 이미지 3/3
    • Remove S pen.
  3. Samsung Galaxy Note5 Teardown: 3 단계, 이미지 1/3 Samsung Galaxy Note5 Teardown: 3 단계, 이미지 2/3 Samsung Galaxy Note5 Teardown: 3 단계, 이미지 3/3
    • Heat the back cover and cut it sticker underneath. Really strong adhesive. Please be careful with the glass and edged back cover.
  4. Samsung Galaxy Note5 Teardown: 4 단계, 이미지 1/1
    • Remove the back cover. And the white strip is adhesive sticker.
  5. Samsung Galaxy Note5 Teardown: 5 단계, 이미지 1/2 Samsung Galaxy Note5 Teardown: 5 단계, 이미지 2/2
    • Twist off all 20 screws together.
  6. Samsung Galaxy Note5 Teardown: 6 단계, 이미지 1/3 Samsung Galaxy Note5 Teardown: 6 단계, 이미지 2/3 Samsung Galaxy Note5 Teardown: 6 단계, 이미지 3/3
    • Push the front assembly out from middle housing. There are a little black adhesive sticker on every corners.
  7. Samsung Galaxy Note5 Teardown: 7 단계, 이미지 1/3 Samsung Galaxy Note5 Teardown: 7 단계, 이미지 2/3 Samsung Galaxy Note5 Teardown: 7 단계, 이미지 3/3
    • Release battery connector from motherboard and pry the battery up. Yes, there is also some adhesive underneath.
  8. Samsung Galaxy Note5 Teardown: 8 단계, 이미지 1/2 Samsung Galaxy Note5 Teardown: 8 단계, 이미지 2/2
    • Remove two pieces of signal flex cables. And different versions Samsung Galaxy Note 5 may have only one piece signal cable.
  9. Samsung Galaxy Note5 Teardown: 9 단계, 이미지 1/2 Samsung Galaxy Note5 Teardown: 9 단계, 이미지 2/2
    • Release LCD connector, digitizer connector, earpiece assembly connector, home button connector on the motherboard.
  10. Samsung Galaxy Note5 Teardown: 10 단계, 이미지 1/3 Samsung Galaxy Note5 Teardown: 10 단계, 이미지 2/3 Samsung Galaxy Note5 Teardown: 10 단계, 이미지 3/3
    • Release USB board connector on the back and remove the whole motherboard.
  11. Samsung Galaxy Note5 Teardown: 11 단계, 이미지 1/3 Samsung Galaxy Note5 Teardown: 11 단계, 이미지 2/3 Samsung Galaxy Note5 Teardown: 11 단계, 이미지 3/3
    • Remove the rear camera. There is a black plastic bracket around camera. So we have to remove them together. And there is a little adhesive underlying.
  12. Samsung Galaxy Note5 Teardown: 12 단계, 이미지 1/2 Samsung Galaxy Note5 Teardown: 12 단계, 이미지 2/2
    • Remove front camera and noise-canceling mic.
  13. Samsung Galaxy Note5 Teardown: 13 단계, 이미지 1/2 Samsung Galaxy Note5 Teardown: 13 단계, 이미지 2/2
    • Remove motor vibrator easily.
  14. Samsung Galaxy Note5 Teardown: 14 단계, 이미지 1/3 Samsung Galaxy Note5 Teardown: 14 단계, 이미지 2/3 Samsung Galaxy Note5 Teardown: 14 단계, 이미지 3/3
    • Remove earpiece speaker assembly.
  15. Samsung Galaxy Note5 Teardown: 15 단계, 이미지 1/1
    • That's Samsung Galaxy Note 5 earpiece assembly. It's integrated by speaker and sensors.
  16. Samsung Galaxy Note5 Teardown: 16 단계, 이미지 1/2 Samsung Galaxy Note5 Teardown: 16 단계, 이미지 2/2
    • Now try to separate LCD screen from frame. The difficulty and risk to remove screen alone are getting nearly 5 stars (5 scores all together)respectively. The screen is weak and the adhesive are strong as well too much.
  17. Samsung Galaxy Note5 Teardown: 17 단계, 이미지 1/2 Samsung Galaxy Note5 Teardown: 17 단계, 이미지 2/2
    • Since Samsung applied the design that the USB board come with soft keys together, DIY replace USB board and LCD screen alone become much more difficult.
    • Be careful with the soft sensor keys on the bottom especially the flex.
    • In fact, the replacement of Samsung Galaxy Note 5 LCD screen, USB board or home button nearly the same with that teardown.
  18. Samsung Galaxy Note5 Teardown: 18 단계, 이미지 1/2 Samsung Galaxy Note5 Teardown: 18 단계, 이미지 2/2
    • Loosen two soft sensor keys from frame carefully. And remove the last securing screw on USB board.
  19. Samsung Galaxy Note5 Teardown: 19 단계, 이미지 1/2 Samsung Galaxy Note5 Teardown: 19 단계, 이미지 2/2
    • Remove the USB board finally.
  20. Samsung Galaxy Note5 Teardown: 20 단계, 이미지 1/3 Samsung Galaxy Note5 Teardown: 20 단계, 이미지 2/3 Samsung Galaxy Note5 Teardown: 20 단계, 이미지 3/3
    • Could you see the mark on the right of the home button? Push the button as its direction and can loosen it from securing slot easily. And then cut the adhesive sticker under the flex.
  21. Samsung Galaxy Note5 Teardown: 21 단계, 이미지 1/2 Samsung Galaxy Note5 Teardown: 21 단계, 이미지 2/2
    • Remove home button flex. Though it's a small component, it's really complicated and difficult to replace, even at the risk to break the screen.
  22. Samsung Galaxy Note5 Teardown: 22 단계, 이미지 1/1
    • Done.
Sophia
회원 가입일: 03/25/14
43,810 평판
안내서 62개 작성하였습니다
댓글 24개
the SIM reader can be changed. the SIM is external or integrated in the motherboard
hammadi - 답글
Can the s pen be opened too? I wanna know because my s pen clicking mechanism gets stuck and doesn't click.
Alex akerez - 답글
Yes it separates at the seam where the darker section with the Samsung text meets the light gray part. Here is a decent youtube video some guy made: https://youtu.be/ixNXUh2fnZo I would recommend trying plastic tools to open instead of a razor blade, also graphite is quite messy so I would probably use a small dab of light silicone grease. I buy it at the hardware store in the plumbing section (used for faucet seals). It's a good lightweight grease for rubber & plastic parts and anything sensitive to petroleum base grease. Good luck!
Andrew Kauffman -
Is the memeory stored on the motherboard? Or elsewhere?
ziefern n - 답글
So did you find out where is the memory stored? My Note 5 dropped in water and circuit on the motherboard is fried. Is there a way i can still recover my data???
parag_oberoi30 -
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 23
30일 전: 83
전체 시간: 148,969
