주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Sega CD 수리는 저희 서비스 설명서를 사용하십시오.
  1. Sega CD Teardown, Sega CD Plastic Housing Removal: 1 단계, 이미지 1/2 Sega CD Teardown, Sega CD Plastic Housing Removal: 1 단계, 이미지 2/2
    • Using a Phillips head screwdriver remove six screws from the bottom of the console.
    • The six screws are marked.
  2. Sega CD Teardown: 2 단계, 이미지 1/1
    • Remove the two screws that attach the Genesis' connector to the rest of the console.
    • The two screws are marked in the diagram.
  3. Sega CD Teardown: 3 단계, 이미지 1/1
    • Slide the lock tab to the left to separate the halves of the console.
  4. Sega CD Teardown: 4 단계, 이미지 1/1
    • Lift from the left side to remove the top of the case.
  5. Sega CD Teardown: 5 단계, 이미지 1/1
    • Using the spudger, pry the cover off of the Genesis attachment.
  6. Sega CD Teardown: 6 단계, 이미지 1/1
    • Lift the top of the case to remove the cover.
  7. Sega CD Teardown: 7 단계, 이미지 1/1
    • Remove the faceplate by pulling it up, then out.
  8. Sega CD Teardown, Genesis Connector: 8 단계, 이미지 1/2 Sega CD Teardown, Genesis Connector: 8 단계, 이미지 2/2
    • Using a #00 Philips screwdriver remove the two screws that attach the Genesis adapter to the console.
    • Disconnect the adapter from the console by carefully pulling the adapter out.
  9. Sega CD Teardown: 9 단계, 이미지 1/1
    • Remove the four screws from the metal plate as shown using a #00 Philips screwdriver.
    • The four half inch bronze screws are indicated by the yellow marking circles.
  10. Sega CD Teardown: 10 단계, 이미지 1/2 Sega CD Teardown: 10 단계, 이미지 2/2
    • Carefully remove the metal cover from the connector by sliding the cover up and out.
  11. Sega CD Teardown: 11 단계, 이미지 1/2 Sega CD Teardown: 11 단계, 이미지 2/2
    • Remove the connector from the housing.
  12. Sega CD Teardown, CD Tray: 12 단계, 이미지 1/2 Sega CD Teardown, CD Tray: 12 단계, 이미지 2/2
    • Remove metal plate by unscrewing the three screws with the Phillips head screwdriver and then lifting the plate.
    • The three screws are shown on the diagram.
  13. Sega CD Teardown: 13 단계, 이미지 1/2 Sega CD Teardown: 13 단계, 이미지 2/2
    • Remove the two screws from the plastic bar.
    • The two screws are shown pictured.
  14. Sega CD Teardown: 14 단계, 이미지 1/2 Sega CD Teardown: 14 단계, 이미지 2/2
    • To remove the CD tray
    • Remove the four screws with the Phillips head screwdriver.
  15. Sega CD Teardown: 15 단계, 이미지 1/1
    • Carefully unplug the wire connected to optical reader.
  16. Sega CD Teardown: 16 단계, 이미지 1/2 Sega CD Teardown: 16 단계, 이미지 2/2
    • Remove the four screws on the underside of the CD tray with a small Phillips head screwdriver.
    • The four screws are highlighted on the diagram.
    • The four springs below the circuit board are attached to the screws, so be careful not to lose them when you remove the screws.
  17. Sega CD Teardown: 17 단계, 이미지 1/1
    • Carefully remove the CD tray from circuit board.
  18. Sega CD Teardown, Motherboard/AC Power Board: 18 단계, 이미지 1/3 Sega CD Teardown, Motherboard/AC Power Board: 18 단계, 이미지 2/3 Sega CD Teardown, Motherboard/AC Power Board: 18 단계, 이미지 3/3
    • Remove the two bronze screws from the metal plate with a medium Phillips head screwdriver.
    • The screws are marked on the diagram.
    • Carefully lift the metal plate up to expose the motherboard.
    • There is a wire strip running through the metal plate that is soldered to motherboard and power supply board. The plate cannot be completely removed. Do NOT force plate upwards. All the ribbon cables can be safely unplugged by simply pulling them out of their slots.
  19. Sega CD Teardown: 19 단계, 이미지 1/2 Sega CD Teardown: 19 단계, 이미지 2/2
    • Carefully lift off the metal plate, the motherboard, and the CD tray circuit board. Then, flip each piece over, as pictured.
  20. Sega CD Teardown: 20 단계, 이미지 1/3 Sega CD Teardown: 20 단계, 이미지 2/3 Sega CD Teardown: 20 단계, 이미지 3/3
    • Remove the two screws from the power supply using a medium Phillips head screwdriver.
    • The two screws are marked on the diagram.
  21. Sega CD Teardown: 21 단계, 이미지 1/1
    • Remove the power supply unit from the console by lifting the unit up.
  22. Sega CD Teardown: 22 단계, 이미지 1/1
    • This is what the motherboard unit will look like once removed.
  23. Sega CD Teardown, Sega CD Teardown: 23 단계, 이미지 1/1
    • Teardown complete!
Ryan Kotzebue
회원 가입일: 10/07/10
271 평판
안내서 4개 작성하였습니다
Cal Poly, Team 5-14, Maness Fall 2010 Cal Poly, Team 5-14, Maness Fall 2010 회원
CPSU-MANESS-F10S5G14
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 24
30일 전: 139
전체 시간: 16,702
