주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. PlayStation 수리는 자사의 서비스 설명서를 사용하세요.
  1. Sony PlayStation SCPH-9002 Teardown, Sony PlayStation SCPH-9002 Teardown: 1 단계, 이미지 2개 중 1개 Sony PlayStation SCPH-9002 Teardown, Sony PlayStation SCPH-9002 Teardown: 1 단계, 이미지 2개 중 2개
    • Here's the PS1.
    • Turn the PS1 over and remove the six screws.
    • Note: part number +BV 3X14
    So far looking good. I'm commenting as you are making this teardown.
    Nicholas Ouimet - 답글
  2. Sony PlayStation SCPH-9002 Teardown: 2 단계, 이미지 1개 중 1개
    • Remove the top cover. It's very easy.
  3. Sony PlayStation SCPH-9002 Teardown: 3 단계, 이미지 1개 중 1개
    • Disconnect both CD-ROM connectors.
    • CD connector one and the socket it connects to.
    • CD connector two and the socket it connects to.
    • Note: part number DEVICE OPTICAL KSM-440AEM
  4. Sony PlayStation SCPH-9002 Teardown: 4 단계, 이미지 2개 중 1개 Sony PlayStation SCPH-9002 Teardown: 4 단계, 이미지 2개 중 2개
    • Remove the CD-ROM reader. You should be able to pull it out gently, although you may have to wiggle it around a bit to loosen the rubber holders.
  5. Sony PlayStation SCPH-9002 Teardown: 5 단계, 이미지 1개 중 1개
    • Detach both cables. They go to the power supply and to the memory cards and controller connectors.
  6. Sony PlayStation SCPH-9002 Teardown: 6 단계, 이미지 1개 중 1개
    • Remove the four screws and the metal cover.
  7. Sony PlayStation SCPH-9002 Teardown: 7 단계, 이미지 2개 중 1개 Sony PlayStation SCPH-9002 Teardown: 7 단계, 이미지 2개 중 2개
    • Now you have the motherboard!
    • And the power supply.
    • Remove the four screws from the motherboard and the power supply.
  8. Sony PlayStation SCPH-9002 Teardown: 8 단계, 이미지 1개 중 1개
    • Once the screws are removed, remove the power supply.
  9. Sony PlayStation SCPH-9002 Teardown: 9 단계, 이미지 1개 중 1개
    • Remove the motherboard, and both of the screws from the memory card/ controller connection mechanism.
  10. Sony PlayStation SCPH-9002 Teardown: 10 단계, 이미지 1개 중 1개
    • Now, you have all your PlayStation 1 parts!
    • Main Board
    • Lower Casing
    • EMI Shield
    • Power Supply
    • Disk Reader
    • Memory Card/ Controller Mechanism
작성자
9다른 기여자 명과 함께
imacg517
회원 가입일: 05/06/10
182 평판
안내서 1개를 작성함
1가이드 댓글
That’s a PAL PS1. May be different from NTSC models.
Daniel Powers - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 18
지난 30일: 97
전체 시간: 29,217
