소개
We've been saying it for years: Any product that can have embedded electronics, will (eventually) have embedded electronics. Today we have a new cyborg hitting the teardown table: the Xiaomi MiJia QiCycle Folding Electric Bike. This is the first vehicle on our chopping block, so we’re excited to dive into a whole new class of device. Has Xiaomi managed to make the ever-repairable bicycle smarter, without making it a nightmare for DIY tinkering? Let's get rolling on this teardown and find out!
If you want to keep up with the tech news, don't pedal harder, just follow us on Instagram, Twitter, and Facebook!
필요한 것
Look at you, little mobile friend. Quite stylish from the outside we take a look at the specs:
250 W, 36 V high-speed motor M108RL from Ananda
0.21 kWh battery (with 20 NCR18650PF Li-ion cells)
45 km of biking power on a single charge
Shimano Nexus 3-speed gear hub
Torque measurement sensor adjusts power based on your pedaling
Trip computer combined with controller to provide real-time stats for speed, distance, power etc.
For those of you not familiar with foldable electric bikes, here's another, the classic, yet analogue Brompton folding bicycle, for comparison. (It's a bit more macro than our usual comparisons.)
The QiCycle has a smaller wheelbase (870 mm) with smaller tires (16"). The fixed handlebar and saddle max out lower too (bad news, riders over 5'6"/170 cm).
The built-in bike computer can switch between four power modes and monitors real-time riding data. (And a smartphone app has a ton of info, too).
I bought one of this but how can i change LCD language from chinese to english?
Stessa domanda come si aggiorna a inflese
. Dolcclod - 답글
Enough talk, lets strip this vehicle down starting with the easiest part: the saddle. Two quick-release clamps later it's free!
The seat post locks the rear rocker arm in place, so once removed the bike can fold up.
Next unscrew the fancy folding pedals. This mechanism reduces the overall width of the bike when folded.
What are the dimensions of the seat post? Also, can it be replaced with one with suspension? If so, what brands/models do you recommend?
Hi Alberto, I have a Dahon 33.9 Thud buster long travel seat post from my Dahon jetstream folding bike, the Qicycle also has seat post size 33.9. When I tried the Thud buster on my Qi cycle I ran into a problem with metal shims inside the Qi cycle seatpost keeping the Thud buster from sliding in unfortunately. Hope this helps.
The chain runs outside the rear rocker swing, and has a handy rear chain stretcher, making removal pretty simple.
The chainring has 52 sprockets whereas the rear hub gear counts 14 sprockets. That gives us a ratio of 1:2.7 in first gear, 1:3.7 in second gear and 1:5 in third gear.
The chain itself has 96 links. There's no master link for opening the chain but a standard chain tool can pop out any link.
So the chain is a single speed Narrow (3/32) or Wide (1/8)?
Thanx
Michele
Chain is wide and I think the chain line is not right. The chain makes a noise not unlike poorly adjusted derailleur transmission. The cog appears to be Y32203200 and seems to me the only reason to use a wide chain. It is deeply dished to get clearance from the hub and moves chain out of line with the chainring.
I was mistaken in thinking the wide chain was needed only because of the 14t cog. I think I can get better chain line with 16t nexus sprocket but still have to use that wide chain. Not going very fast by pedaling, but pretty easy to climb even without any assistance.
Taking the crank arms off takes a little preparation, a cover must be removed before you can fit the crank puller on. But after that it pops out like any other bike's crank.
The next piece of the power conveyance puzzle is the bottom bracket.
Again we need a standard bike tool—the cartridge bottom bracket tool—to loosen this piece of hardware.
can we replace the bottom bracket with standard ceramic bearing bb out there in the market?
which is the size of the bottom bracket?
i would like to swap the plastic cheap one for one of better quality.
kind regards
from this video, the man replaced it with the
Central movement FSA RPM 7420 68x118mm
Hey Guys, can someone tell me what is the size of the screws holding the crank? I unfortunately lost the right one and now I have a crank loose, therefore I will not be able to ride the bike until I get a replacement.
The later version has a different bottom bracket. The chain ring is attached to bottom bracket and not the crank arm. I guess it is possibly OEM variant of Ananda bottom bracket S15. It says bbts1sd on a sticker attached to the frame.
Si quelqu'un peut donner les infos après démontage du modèle ef1 ou/et ef2 ce serait top ;-)
A nice feature for the QiCycle is this Shimano Nexus 3-speed hub. We easily dismount the bellcrank and take out the bolt which runs to the inside of the hub.
At the opposite end of the bike, we pull off the rubber handle and remove the shifter grip.
devo cambiare copertone quindi devo togliere la ruota, in che marcia (rapporto) devo mettere per togliere la ruota dalla bici?
voi avete scritto in marcia (rapporto) n3 ma nella figura mostrate che sta in marcia (rapporto) n1
qual’è la maniera corretta per togliere quindi la ruota dalla bici? deve essere inserita la marcia - rapporto 1 o devo inserire la 3 ?
ed invece se voglio smontare il cambio deve eressero in che marcia (rapporto) ? nella marcia 3?
se voglio regolare il cambio ho capito che deve essere nella marcia (rapporto) 2
The rear wheel has a hub roller brake, a style of drum brake. It is operated by hand brake lever so you can backpedal freely.
We start to fish out the brake cable, but it looks like it's riveted to the hub assembly, and will stay attached at that end.
So we loosen the bolt holding the hub to the frame and lift out the 16" wheel with its 28 spokes, 3-gear hub and roller brake, and its trailing brake cable...
Ciao ragazzi, come fare a regolare il freno posteriore?
Il mio frena troppo poco, devo praticamente tirare del tutto la leva per avere un effetto frenante di un certo livello.
Grazie!
Peut-on remplacer ?
BR-IM31-R 520 grammes d'origine par:
BR-C3000-R ou
BR-C3010-R mm +10% de puissance de freinage ou
BR-C6000-R poids 660 grammes
Of course we wouldn't be tearing this bike down if it weren't a smart bike. So it's about time we check out the speed sensor.
The cable connects under the seat then runs along the frame to the (modular) dropout.
We're able to peel the cable out, and free the sensor assembly.
How we can disable the speed limit?
It's imposed by the software.
The Chinese firmware limits the assist to speeds under 20km/h. The European aids you until you reach 25km/h. An unofficial firmware sets the limit speed up to 29km/h I think.
My bike has bb torque sensor of type bbts1sd, I can't find any info on that. Looks like it has external bearings. Bike frame doesn't have any qicycle or mijia decals (only tiny mi decals here and there) and it looks like it was thinly sprayed over with matte black paint. I paid €1000 for it, it's an unused bike with full warranty. Manufactured in 2020.
Pushing out the small circuit board, we get to the meat of this miracle measurer:
A Micronas HAL1820A programmable linear hall sensor
The three wire system is connected with a simple JST connector, not solder. Now that's what we call modular.
It does measure rpm but likely not the wheel but rather the sprocket. This piece of data is then combined with the amount of deflection the chain shows. Nothing much on a city bike like this so the sensor needs to be super sensitive so super expensive. Later versions of this bike use cheaper sensor located at the bottom bracket.
Back to something more mechanical we unmount the front brake—a standard dual-pivot side-pull caliper brake.
To find more electronic components we aim for the front wheel with its hub gear motor.
A simple tug disconnects the hub motor cable so we can finally take out the front wheel.
With the cover lid unscrewed we can push out the source of rotary motion and discover a small circular board behind the rear cover of the motor.
Besides distributing power it also has three sensors (every fourth coil) for measuring the speed.
The three gears on the flip side are made of plastic to keep abrasion to a minimum.
Ist der Hersteller des Motors bekannt bzw. nach dem Öffnen zu Erkennen ?
Kann es sein, dass der Motor hergestellt wird von:
Changzhou Huayu Xinfeng Motor Co.ltd ?
Hallo Joerg, den Hersteller des Motors konnten wir bislang noch nicht herausfinden. Die Aufgedruckte Nummer am Motor gab auch keinen Aufschluss über die genaue Herkunft (MV8536VN2C5AN16GF2648). Huayu Xinfeng Motor Co.ltd stellt einige verschiedene Motoren her, jedoch habe ich auf den ersten Blick diesen Motor nicht darunter entdeckt.
Please I'm not quite get how to open the hub motor, I've already unscrew 3 screw on the cover lid, still the hub not open, please help.
consigue 3 tornillos de la misma medida, pero mas largos, retiras los tornillos originales, y pones los largos, y haces fuerza en contra de la manecilla del reloj. Si aún asi no puedes, entonces, calca los orificios en una lamina de madera, tres huecos para los tornillos, y un hueco mas grande en el centro, algo asi:
______________________________________________________
_______________________________________________O_____|
______________________________________O__( o )________|
______________________________________________O______|
______________________________________________________|
john -
Same problem here, did you manage to open it? because no answer after 2 years….
Why the planetary gears are plastics?
Does they transfer the power too?
Hi, when looking at the specs for this motor, it clearly says 30Nm, while i know xiaomi has 7,3 Nm in their spec sheet. I think Xiaomi got it wrong and is under selling the torque http://ananda.com.cn/index.php/wap/produ...
I suspect the value given by motor manufacturer is when you use a cheap square wave controller. Here Xiaomi has chosen enough computational power to run a much better sine wave controller, resulting however a pretty expensive bike for what it is. Well, it says smart in it's name at least where I live. They make another version in their himo range that comes with bigger wheels or some kind of rear suspension cast wheels and disk brakes. They are likely punchy and noisy just like some people like. And drive like a moped if fitted with a throttle lever.
how could I disassembly the front-hub after removing that little three side cover screws?
Hi, in case we need to replace the plastic gears can we buy them anywhere? or should we make them?
Who is the engine manufacturer?
And now, welcome to the middle of the teardown.
We stripped the QiCycle of most of its bike parts. The aluminum skeleton we are left with weighs 5.5 kg which is over a third of the overall weight.
We go ahead and pull the main plug from the top tube, enabling us to extract the nervous system linking all the electronic components.
The available parts appear to be for the Chinese version with an accelerator lever. Later versions of eu conforming bikes have yet another kind of harness with wires from the brake levers.
Did you found the Eu version of the harness ?
I have the same problem and can't find the good one.
Thanks
did anyone find this af of yet? mine broke as well in the eu version
Only 4 Torx screws hold the cover of the bike computer and the 160×128 pixel TFT screen is attached with a simple ZIF connector.
On the flip side of the board we find the following chips:
MediaTek MT6261A ARM processor
Microchip PIC16LF1518-I/MV PIC controller
CSR 1010D A05U bluetooth smart IC for lighting
Texas Instruments TPS259240 eFuse with over voltage protection
Winbond 25Q128FV 128 Mb serial flash memory
STMicroelectronics accelerometer
How to factory reset the trip computer?
Hi ifixit,
How did you remove the metal plate that protects the MTK 6261A CPU and the Winbond 25Q128FV CHIP ?
Best Regards
Carefully ;) but with the help of a side cutter. Removing those shields is not recommended and might effect the function of the chips.
Hey !! Take a look at this playlist.
30 minutes, and you will have your translated QiCycle !!
Hello I accidentally dropped the bike and the cover of the bike computer is cracked (thankfully the display looks to work fine). Any ideas where I can get a spare accessory for that cover?
I have a same issue did you find the computer mont?
Thanks
Still haven’t found a spare part for this. It looks like you could get the whole display from Aliexpress but they don’t sell it any more.
loukis -
Same problem for me, just received and the under-cover of that accesory arrived broken..
Hi there, I have the same problem, unfortunately the guy that sold me the bike told me that during the shipping the display holder has got damages, now it’s more or less fixed but I would like to change it, without changing the whole thing that is perfectly working…
Do you know how could I do it?
A guy in Spain is selling screen protectors.
His mail: felixfazer@gmail.com
Xiaomi Qicycle EF1 protector de pantalla
where can i find a new screen or a new bike computer?
mine is broken.
thanks
Hi santos. You might want to check out the additional link (wordpress page) here: MiJia QiCycle Folding Electric Bike
no display to buy :( thanks
We saved the best, or at least the most power-ful, for last—the battery tube!
The tube can be removed single-handedly, with just the push of a button, and can be charged in 3 hours with the 5-pin connection on the side.
A good amount of the bike's weight is this battery—it weighs 1.46 kg, fully charged of course. ;)
The bike's battery capacity measures in at 5800mAh (208.8Wh). For your pointless comparison of the day, that's more than 5 iPad Pro 12.9"!
We begin to pry out the rear light, a cable keeps it in place, but it does give us access to some hidden screws. This in turn grants us access to the internals.
This massive umbilical leads from the charging port to the batteries and the BMS (Battery Management System) at the other end, and an LED board behind the rear light.
We peel out said circuit board and discover some secrets. This guy controls the rear LED array, as well as some status LEDs along the top of the tube (probably to indicate battery activity).
I’m having trouble prying out the rear light. It’s pretty stuck in my case. What kind of force should be used? Should I rotate it? Or should I pull it?
We used a heavy duty suction cup for a better grip. Try turning it counterclockwise. It sits very tight.
I had to use a craft/hunters knife to slowly pry it apart then suction cupped it off once loosened
R E-cycled - 답글
The main battery compartment is a tough nut to crack. Five screws (hidden by some hard to pry off covers) aren't all that hold this case together.
As we finally succeed with some gentle heating and "good vibrations" we snap open the case, breaking one-time-use clips in the process. Bad news for battery cell replacements.
We finally reach the prize: 20 Panasonic NCR18650PF Li-Ion batteries! Panasonic is a good (safe) brand, so recharging should be a breeze, even if individual replacement won't be.
The battery pack also has a battery management system (BMS) circuit board.
Hello, I build and repair Ebike Battery Packs, see ebike-workshop.com, yes it would be possible to charge this Pack using a separate Pack, but proble is:
- the extra pack supplies too much current, the BMS Charging board would be distroyed or stop this “Super-Charging”, since it is not made for currents above 2-3 Amps. higher Charging currents would also reduce lifetime of the internal 18650 Cells
What you would need is an additional, external 36v (fused!) batteryPack which is connected directly to the Battery + - and increases the internal capacity like I suggested for M365 E-Scooter on my website. this would be permanently connected and can be charged with the original charger.
Who knows if it's possible to replace the cells with the more capacitive ones?
yes it seems possible to change the cells with higher capacity than the original 2900mAH make sure to buy the right format 18650 with at least a Continuous Discharge Rating of 10A. I advise to buy a few more cells to test that all cells are around same (not sure what to check and with what?) .
What tools or technical works is need to replace the cells once the battery is opened?
Could you say more about the gentle vibrations?
I’ve been trying to open the battery without much luck. So far, I managed to split the part near the seatpost. I’ve used all my own force to crack it open without luck.
Do you have further tips and pointers?
So I finally managed to open it by creating a lever to amplify the force to crack it open. To my own surprise, my battery contained Samsung 29E cells. The battery cells were built together very well, with several protection mechanisms in place, including a heat sensor.
IR Here -
I’ve stripped out the cells and the BMS. Then I wired a new battery pack directly to the GND and VCC. I’ve done a test ride of 5 km and it’s working well.
Few notes:
- backlight doesn’t work anymore
- the display always shows “low voltage”
IR Here -
Hi am trying to replace the original battery with another one . Could you please send me som pictures or provide me with the controller diagram pins that goes to the battery since the battery have only red + and black- and the controller have 5 pins coming. I would be really thankful if you can help and send the a picture or explain how to connect the battery. Here is my mail: robotiger@gmail.com
The board is packed with lots of resistors. What sticks out are these components:
An ATMEL MEGA 328P Battery Management MCU
Ablic (formerly Seiko Instruments) S-1142B33H-E6T2U 200 mA LDO regulator
FL12.000 12 MHz quartz crystal oscillator
On the flip side we find these:
Magnachip MDU1931 single n-channel trench MOSFET (x4)
RS2M rectifier
interessant wäre ob das BMS beim Zellentausch abschaltet, oder diese Möglich ist, um z-Bsp Leistungsfähigere Zellen einzubauen, wie ich es unter www.ebike-workshop.com mache: 3500maH Samsung, dann hätte der Akku 7aH.
I made a tutorial for Changing a Custom Boot Logo for Qicycle :
Alguien sabría decirme donde se encuentra el sensor de temperatura en la placa bms? mi cargador no carga y creo que puede ser por un fallo entre la batería y el cargador por el dichoso sensor que le puede alertar de temperatura alta y deja de cargar y la luz del cargador se queda en rojo intermitente
Reasons for not charging the battery, It is a fault of the battery control board.
Normally the controller board will supply 100v+, but the faulty controller board will only supply 50v.
Does anyone know of any repair information without replacing the control board ?
thank you.
We return to the bike's body to do a bit more disassembly before tackling the final electronics.
The bike's main hinge—the rear swing fork—is held to the top tube with a simple Allen bolt.
When detached from the frame we can clearly see the tilted asymmetric hinge.
The second important compact-ifier is the foldable handle bar and stem. The mechanism itself is cool, and comes easily apart with the pull of a pin.
To take the front fork off the hinge, we make use of the uncommon, but essential, 10 mm allen key, an essential for bike repairs.
Could you please provide detailed dimensions of the fork?
The fork is wide enough to house a roller brake but they didn't fit a spacer. Also the axle is longer on the gear side as you can see in the picture on this guide. Another of those anti rotation washers was fitted on the inside of the fork but it's not very thick as you are supposed to add a lock washer under the nut. I think there should be a 5mm thick spacer between the hub and fork or a 3mm spacer if that non turn washer is inside of the fork. This factory setup likely puts the fork under strain until it gets broken.
The
braincontrol unit is mounted to a handy handle that attaches to the frame with two simple screws. -
Having removed the screws, we can grab the controller unit by the guide rail and slide it right out.
This bike's brain is a single unit electric bike controller by Ananda, a manufacturer of many electric bike components.
이 단계에 사용된 도구:Jimmy$7.95
Of course "single unit" doesn't mean much to us, we dive in past some standard Phillips screws, and work on prying the stubborn casing open.
We grab a Jimmy and iFixit Opening Tools and try to negotiate–without any success, even when heated.
We turn our efforts to the side panel, and what we found inside will shock you (people always fall for that, right?)
Three boards—bridged by an army of pins—are drowned in gobs of yellowish transparent rubber.
Le caoutchouc jaunâtre est en fait ici pour isoler tous les composants et le circuit, de l'humidité et des vibrations. Par contre, cela empêche toute intervention de réparation des composants.
Most of the important components live on the battery pin board, we spy:
STMicroelectronics STM32100C8 micro controller with an ARM Cortex-M3 32-bit RISC core
Microchip MCP2003 LIN J2602 Transceiver
Diodes Incorporated AS358M low-power dual operational amplifiers
GH17M transistor
The rest of the goop-covered boards mostly carry capacitors and other passive components.
And with that, this bike has been folded, unfolded, and torn totally down.
Nice job, I've just received one of these and am much happier with my purchase after learning about the inside of this sweet ride. Thanks!
- Standard bicycle components and tools are used throughout, making repair more accessible.
- The battery assembly can be removed and replaced with ease.
- The electronic components can be removed without compromising the bike, extending its life and making recycling easier.
- The seatpost, frame, and front hub motor are nonstandard, making a replacement a bit more difficult when the manufacturer does not offer them.
- The battery pack is a complex assembly that makes for wasteful replacement when individual components fail.
최종 의견
수리 용이성 점수
(10은 가장 쉬운 수리를 뚯함)
댓글 131개
My axiomi qicycle seat post keeps slipping down despite locking d 2 release clamps tightly. Caused a fall from d bike as d seat post slipped and hit d ground jamming d moving bike. How to tighten d 2 clamps to ensure no slippage especially cycling at a higher speed?
Thanks
The quick release clamps can be adjusted by using the bolt on the opposite side of the handle and tightened by closing the handle. The QiCycle is constructed for max 100kg weight. You may also try cleaning the seat post for a better grip (maybe it got a little greasy during the assembly).
I am wondering if the two saddle clamps can be replaced. And if so where to find them? Help very much appreciated :).
The saddle clamps should be replaceable with standard quick release clamps of the correct size. Depending on the design the handle might not be curved like the original one and therefore stand off a little bit.
Thank you for all the pictures. Unfortunately after a drop of the battery my taillight is not switching on anymore. Do you have detailed pictures of the disassembly of the taillight. Maybe it is only a connector that is loose... Thank you :)
Hi Montie, we don't have a separate guide for the back light yet. But to get it off, you need to grab it very tight and turn it counter-clockwise. The rest can be seen on the pictures in step 16 (four screws and the cables inside).
Hi Tobias, thanks for the fast reply. I know how to get to the connectors (thanks to your good illustration) but I need to get *into* the light because the connectors which are visible seem to be okay. Obviously I have to peel the red plastic off which is not clipped but sealed. The back (black part) of the light is one single plastic part if I see this right. Any further help would be nice. Should I use a knife? I don"t want to destroy anything...
Hi Montie, getting into the light itself without "destroying" it looks quite impossible I guess (we haven't tried it). The light looks as if it is sealed from both sides, front and back.
Hi!
My Charger seems to be dead. Even LED Indicator wont light up and it doesnt charge the bike. Do u have any advice or guide to open it up, or to work the batteryside connector onto another fitting charger?!
Thx
Hi Andreas, unfortunately we haven’t torn down the charger itself. Charging the battery via other means sounds like an experiment I would not recommend unless you know what you are doing.
Same with the case you are experiencing, is it now resolved? If so, I would like to get feedback on the issue from you. Thank you
There is a firmware update. It came automatically to me via the app. I mean I was asked within the app whether I wanted to upgrade the firmware that would lead to 25km/h.
Just FYI: firmware update seems to be possible only by using an Android device, not iOS.
I didn’t get any update firmware . what’s the last software version indicated in bicycle info in the app?
What does the Max speed mean?
If I'm pedaling quicker than 20km/h then the engine will not help me to reach 30?
Is there mode how can I ride 20km/h without pedaling?
Hi,
I tried to upgrade the Qicycle but it never ask me to upgrade the firmware in the app.
Could you say me which app we have to use ?
- https://play.google.com/store/apps/detai...
I tried with iphone too but it don’t work.
The version of the driving computer is : 1.6
Thx for your help.
Janoyolo -
Hello,
I just get this bike and I’m very happy with the quality of the model! Your tutorial is great and very clear, I will not hesitate to consult it if needed.
I have one question for you :
I’m 1,85m tall and I have to put the seat at its maximum position in height but that’s fine. The problem comes from the handle which is a bit low.
Do you know if it could be replaced by a foldable adjustable handlebar ? I’ve seen some on the market, and it would solve this issue.
Thanks for your amazing work.
Léo
Yes, it is possible, something like https://www.aliexpress.com/item/Aluminum...
Although the original stem has much better quality, so I ended up just adding this adapter to make the stem longer: https://www.amazon.com/TranzX-Alloy-Twin...
I have another important concern :
My electric motor is not working on my Qicycle.
When I use the different modes with the pushbutton, I’m not feeling any help from the assistance of the motor. The battery works properly, as well as the on-board computer that displays correctly : the battery level, the current speed, the power in Watt and the assistant mode.
The application shows the message : "One issue found : please check the motor line on the left of the front wheel”
I don’t know how to proceed to fix this. Can you help ?
Thank you
You may want to check the cable on the left hand side of the fork if it is connected properly (see second picture in step 11).
Regarding the height problem in your other comment I’m sorry to tell you that the bike is designed for people under 170cm. The seat post and handle bar post are non-standard components and don’t look like they can be replaced with longer versions.
This is not true, there are 3 options:
1) Replace the stem with telescopic one
2) Add the stem adapter https://www.amazon.com/TranzX-Alloy-Twin...
3) Replace the handlebar with curved one
у меня такая же проблема. кажется, что корпус является монолитным. это не так, как там покрыть возможные отвинтите.
The lid sits very tight. Try to get a grip through the three holes (for example with two allen wrenches) and turn counterclockwise. (Caution: the lids edge is very sharp)
What did you use to open the lid Tobi?
Are you using three allen wrench?
I used two allen wrenches (short part in the holes long part along the axis) and used the axis as pivot point.
Is there a way to buy a battery pack for this bike ? I need one desperately …
yes, through Aliexpress.
Or you can check out some of the mods to the battery that other owners (Youtube and Google) have done to change the battery unit. This will obviously void any warranty.
Jay -
La bici mi é arrivata con il display del computer di bordo scheggiato,infranto il display una volta acceso non é leggibile.
Come posso ovviare a questo? È sostituibile con un nuovo display?Dove posso trovarlo?
Grazie
Aliexpress…. 65€ circa!
The chain jumped down while I went uphill and only low engine support. How can I avoid this in the future?
Hi Jürgen, check the spring on the rear chain stretcher (see step 5). This should provide enough tension for the chain to not jump.
Hello,
What kind of axel and nuts does the front fork have ?
Is it M10 nuts ?
Thank you
Hi Mourey, I used a size 19 wrench, so its probably M12.
hi! great teardown! do you know the dimensions and weight of the batterypack? i'm planning to buy the bike in china and then send the pack in mail, since its not allowed to take the battery in your suitcase or carry-on in airplane.
Hi maurits, the battery pack itself is 46 x 7 x 7 cm (±0.5cm ;) ), weight is 1.46 kg.
Thanks! If its not too much trouble, do you know the size of the bike when folded and the saddle removed? To See if i can fit it in a suitcase without completely taking it apart.
Spiegazione al di sopra di ogni aspettativa. Una pecca, manca la spiegazione su come installare la lingua inglese essendo tutto in cinese.
. Dolcclod - 답글
Dai un’occhiata a questa Playlist.
30 min ed avrai il display in Italiano!!
Michele -
help: I update the firmware with android and now the qicycle go fast to 26 km/h, but the led light rear don’t works more!, instead before it’s ok, also the computer on board don’t read the status of the battery, plase help me!! also other peaple have the same problem…
Hi everyone,
Did anybody find the right antitheft combination for the QiCycle ?
I’m thinking about the Kryptonite NY M18-WL + some Hexlox to secure the saddle, handlebar and wheels. But as I’m still waiting for the bike to be delivered, I can’t really figure out if Hexlox can be used on these wheels.
Anybody tried or has other ideas ?
Thx !
Léa Gilezo - 답글
Hi,
Please can someone help me with the gears? I received my bike on the 28th of this month and I have successfully upgraded to latest firmware. The problem I am having is on the 2nd gear when i pedal it feels like it is skipping, it is not pedalling smoothly. 1st and 3rd gear seem fine and don’t skip.
Any ideas how i can fix this? I notice the yellow dot in the nexus gear is not in the correct lines.
Thanks Az
This is because you have folded the bike in 2nd or 3rd gear, and pulled the gear cable, you need to fold it ONLY in 1st gear.
To fix it now you have to follow this procedure:
Hallo,
mein Qicyle hat anscheinend leider einen defekt. Das Rad schaltet sich von selber aus obwohl der Akku noch 80% hat und am Akku selber noch 4 LEDs leuchten. Auch das Update konnte ich nicht aufspielen, es wurde mir von keiner App (ich hab so ziemlich alle Apps probiert) angeboten.
Hat einer ähnliche Probleme? Ich gehe davon aus, dass der Akku defekt ist. Bei Lieferung war er komplett leer, also keine Statu-LED am leuchten.
Beste Grüße, Christian
Hi Az this could help You
Hi Bobo,
Thanks for the video. I saw this same video earlier today and followed the same steps but I couldn’t get the yellow dot to align in the middle of the 2 lines as shown on the video.
None the less I turned the cable adjustment all the way in and even though the yellow dot isn’t in the middle of the 2 lines it fixed my issue :)
Thanks
Hi, I need to increase the speed of this bycycle, would you help me with the tutorial, the video. Thank you.
Dears, I just received my bike, the app on android proposed me the upgrade. Since then, The onboard computer shows my battery being empty, the red light doesn’t work anymore also the electric assistance doesn’t work. Any way to do a downgrade of the onboard computer? (as on the battery the 4 led lights are on when testing.)
Hi Vincent , take a look here >> http://en.miui.com/thread-710300-1-1.htm... <<
I solved same issue following the instruction of the user julferber ( see page 2 )
Be patient and good luck ;-)
Hi, i have Qicycle EF1 since october. The bike worked well since yesterday. Since yesterday, the bike has some issues that are a little bit annoying.
I think it may be that the speed meter is broken, so it does not detect that the bike is in motion. (posible issue of hub gear motor measuring speed?)
-Display don't show speed screen when I run with it (in 22km of my travel, only show this is screen 2 times only 10 seconds, and the display show 0 km/h, 0km, 0wat) But all time this screen doesn't appear. Only show battery screen, the same screen when you're stopped.
-The display tur off when I'm ridding, like when the bike is stop. 1 min for default setting. When I press a button when I'm reading, the screen wake up, like when the bike is stop.
- I can't change the power assistence, If i change the bike continue to 150%.
- In some cases, the bicycle offers less assistance and lowers the power alone, just a few seconds, without any reason. The engine continues, but with less power.
Thanks!
Correct link:
Probably not. Bike dimensions folded are: 450x1000x650 mm. See product page, under specifications.
Is there a way to remove the speed sensor or trick it to believe it’s going slower than it is?
I mean to increase the top speed past 25kmh which is still a little slow. Or a firmware hack?
hello: I just got the bike and my mother fell with the bike and she hit the screen. I do not know if it has arrived with defect or has been the blow on the screen! The problem is that suddenly the screen turns off and runs out of energy! Sometimes when it is turned off and the lights are on, the back light stays on for a few seconds when the screen is off, until it shuts off completely. I'm about to buy a screen! I could i check in some way that the screen is causing the bike to turn off?
Here is link to fix:
hello,
i have MC and BMS show 000-000-00 and i’ve lose electrical assistance !!
can not update MC and BMS with QiCycle app official or not :-(
Bobo -
Salve, sono Vincenzo
ho una qicycle, che negli ultimi giorni mi sta dando problemi, la sento più pesante ed il motore non mi sembra sia scattante come prima.
Da cosa può dipendere? io mi sono accorto di qualche anomalia al cambio, la marcia 3 non entra alla perfezione e la taratura in seconda risulta non corretta, il pallino giallo si trova fuori dalle due estremità di “set” può dipendere da questo? cmq cercando di settarla rimettendo il pallino al centro , ma quando provo a muovere il cavo di riferimento questo non si muove… che posso fare?
grazie a presto.
* Why has the control unit 5 pins? It labels plus and minus for the 42V so far so good but what is the e.g. Vlm pin for?
* Also the charging cable has 5 pins. Why is that? The battery has 10 cells in series so I guess it cant be for balancing reasons.
* Where can I find such a connector/socket for the control unit plug?
The reason for my questions are that I am planning to do a 42V battery pack by myself.
Hey Martin,
have you figured this out? I’m also interested in this.
IR Here -
Hi guys,
I am experiencing an issue that has been recorded from others as well in the past.
The motor has stopped working since a few days.
The story:
- I had an accident falling off the bike about a month or two ago and since then I have been experiencing problems with the electrical assistance.
- First symptom was that the motor would not work always
The problem here was that the cable attachment under the battery tube on the front (https://i.imgur.com/SQFFSUQ.png) connecting the motor, battery, Hall sensor etc. had been slightly removed because of the usage and the crash potentially. The problem was fixed after it was properly attached.
To get the motor to work again I had to completely stop the bike so the Watts would go back to 0 and then start again.
- I kind of got used to the above problem but then the motor would not work at all. The display works as usual (showing Battery, Speed & Watts ).
I opened the black cable from the motor as in the post below and found one of the three (the blue one) fat wires inside (out of 9 in total) cut. I then used one of those wire connectors https://i.ebayimg.com/images/g/HnoAAOSwG... to connect it back and did it successfully. After removing the cable all the way from the motor to the plug before the torque sensor I tested with a digital multimeter that there is conductive path from each pin of the plug leading to the torque sensor with one pin of the central plug (under the battery) and same between the pins of the plug leading to the motor and the central plug again. So, it seems that everything works correctly with the cable.
Doing the self-test within the app for the bike, I got notified that there is a problem with the front wheel and the left side of the cable . As mentioned previously everything has been plugged correctly and fixed the cables.
My only hypothesis is that either:
1. The torque sensor is not functioning properly (I will try cleaning it as per the link https://translate.google.com/translate?a...). I don’t think it is this having a problem though, cause the Watts displayed are in a normal range that the motor would normally work. Same for the speed therefore the problem must be in the motor
2. The motor has a problem. I have unscrewed the 3 lid screws but can’t open the motor at the moment and even then I wouldn’t know what is the problem and how to fix!
3. There is still a problem with the cable or plugs (eg not making proper contact)
What do you think might be the problem and what should I do next?
hello,
few days ago i bought an used Qicycle. The Bike totally has 12km. Outside it’s in a very good condition.
Now i recognized that the wattmeter still shows “0”. I am sure the motor doesn’t function. Now i need some help .
What I did :
-Flashed back original software now it is :
LINPic 003-013-000
MC 005-017-000 (25km/h)
BMS 018-024-023
Firmware 1.6.613
-Checked Akku -> Loading Okay, Lights Okay
-Checked all cable connections (motor left, controller, display, hall sensor)
-Checked intergrated cable if it is broken. All 16 cable contacts give a signal. I post the wiring of the cable for the community. With my plan you can check if the wiring is ok.
http://up.picr.de/33540863mf.jpg
what could i do now ? Buy a new motor, how could i check if it is broken ?
Buy a new controller ? Does this make sense, because all seems ok. The Qicycle Software says “bike is Ok”
Buy a new “Hall sensor”, don’t know if this could be the problem…maybe a expert could tell me.
If somebody help me to get a solution i would donate something.
harald
Dear Harald,
My integrated cable has more than one pin broken but I couldn’t figure out what wire to check as all 9 wires look intact in appearance. Please send me the wiring color code for pin numbers that are shown in your wring diagram.
Many thanks in advance.
phu dang -
Oh..sorry, at the Moment couldnt find it…
Harald -
There is a strong resistance on front wheel only when turning reverse (no resistace moving forward). Motor not working although computer provide all the data even the watt usage. Pls assist any feedback would be very much appreciated
Hi lousky007!
My bike has the same problem too. I tried unplugging the cable from the controller and the front wheel can be turned backwards without such resistance. I did the same procedure to the hall sensor but the prolem remains the same so a malfunctioned sensor could be ruled out. I guess the segment of cable that connects the front wheel motor to the controller may have some broken wire in it. This segment of cable is very tight so don’t turn the front wheel to the left until it stops as it is prone to failure if you overdo. I ordered a new cable and I am waiting for my delivery. Have you successfully fixed it yet? If yes, please tell me the right cause.
Thank you very much.
phu dang -
Where did you buy this cable?
Karim -
Hi Karim,
I am so sorry for late response. I bought the cable from Aliexpress. Just google it and the results suggest a variety of shops selling it. But at the moment the cable is not available any more. I think you should wait and check it on Aliexpress periodically. In the next five days I will give you the wiring color-pin information, DO NOT discard the cable, it’s the most repairable part once you idenfy the damaged wire(s). I will try get back to you soon. Have a good day!
phu dang -
@phu dang,
sorry i have no color code for the pin numbers, because i only did a measure of the cables. my wiring plan is quite simple you only have to check the numbers of the pins which are wired.
as i wrote above my problem is solved. First problem with the update was an incompatible android smartphone. Changed ist and the update was successful. Second problem was not the wiring, but the hall sensor. Changed it to a new one and evrything was fine.
If you habe broken pins on your cable why don’t you chnage the cable. It costs about 25$ and changing should not be a problem.
Thank you very much for your kind reply. The problem my bike is experiencing may be somewhat that relates to the front wheel motor, the controller, the hall sensor, the cable… I have ordered a new cable on Aliexpress and I am waiting for my delivery. But what if I can’t still fix it? I will try replacing with another part by ordering a new one until the problem is resolved. I will let you and everybody in the forum know the exact cause when i have sucessfully fixed it as a way of sharing experience.
Have a good day my friend.
phu dang -
hello phu dang,
best wishes for you to solve the problem. i understand that you are afraid of not finding a solution, for me it was the same. As i said it is easy to check the cable. take my wirking plan and a voltmeter. you can easy do a measure if there is cntact between the poles. As i read in other forums often the hall sensor was the problem. The motor or the platine/chip/controller is rarely the problem. The motor is verry robust. Are there any errors shown when you do checks with the app ? The app should show contact/wiring problems with the motor. In the other forum someone told me to change the hall sensor and he was right.
Harald -
Hello Harald,
I greatly appreciate your kind suggestions and your helpful information. Because at the moment the cable has not been delivered yet so I cannot do anything with my bike. I’m glad to hear that the motor is robust and it seems to immune to malfunction as this part is very expensive. Could you tell me the app you mentioned that can be employed to check problems relating to contacts/wiring with the motor?
Thank you very much and best regards.
phu dang -
Hello Phu Dang,
its the Original App from Mijia .Maybe it is only in Chinese Playstore. You have to sideload the APK, for example here.
https://www.apksum.com/download/com.velo...
The App cant check the motor or the wiring direct. But for me it was so that it showed no error. For other people it showed errors which mostly have to do with wiring in the front to direction of the Motor.
Harald -
Dear Harald,
Thank you very much for your help. I will try the app and let you know what it’s telling later.
Could you send me the address link to buy the torque sensor on aliexpress?
Best Regards.
phu dang -
Harald -
Hello Herald,
The item from the link is no longer available. I did google the torque sensor and the LCD monitor but I could not find any items that is available at the moment. OMG this time would be a tough one for me. Do you have another link for those items?
Best Regards
phu dang -
In this link First isahown Not available but if you choose delivery country (for me germany) i am able to put it in the basket. 97 items are available
Harald -
Dear Harald,
I picked Vietnam as the delivery country but the message ”sorry, the product is not available at the moment” kept popping up. I think the best thing I can do now is to wait for the cable assembly to arrive and then decide the next step to do. OMG this is a time-consuming task so I’d better stay calm and wait.
Thank you very much for your kind support.
phu dang -
hello jay,
hahaha i am not a technican for qicycle bikes i am a user as yourself. i think if you are good you could do anything with the bike. here is a video which shows the opposite of a throttle, a mod fro full power
https://www.youtube.com/watch?v=gqvqy6Ht...
Video only should show that everything is possible, but i don’t know how to do such mods.
Harald
Harald -
Hi, i have Qicycle EF1 since Feb-2017. The bike worked well since yesterday. Since last tow-day before, my bike front wheel inner tube bust. so i open the wheel bolt nut b4 i unplug hub motor wire,. after replace tube with Tyre, re-fix as well same. after test cycling motor not running… the bike has some issues that are a little bit annoying. the computer display motor speed meter show well battery also 100’/. whats a problem can solve me pls…. here Singapore so hard to find a repair shop…
The saddle clamps should be replaceable with standard quick release clamps of the correct size. Depending on the design the handle might not be curved like the original one and therefore stand off a little bit. https://apkroyal.com/app/six-pack-in-30-...
Très utile, merci beaucoup!
Isabelleni - 답글
Amazing post. I really need some help. The part that connects the seat to the top of the pole has broken on mine and I cannot find the part. I visited many bike stores here in the UK and cannot find a replacement. Also, where is the best place to get a new charger? thanks again
Gazzi Keny - 답글
Hi Gazzi Keny, maybe you’ll find some information here at the answer section: Where can I buy spare parts of Mijia QiCycle Folding Electric Bike?
Hi guys,
I bought this bike as used (the total Kms made by the previous owner was 320, so I consider the bike almost new), and I’m going to use it in order to reach my new work place that is at 55 minutes from my house, hopefully I’ll save a lot of money from transports, and I was wondering if this is actually reliable because I’m gonna do something like 30kms per day.
I’m currently waiting a new battery from aliexpress, in order to be able to cover more distance. Do you think that the Qicycle could be ok?
However I have one little problem: the plastic that holds the display to the handlebar was broken due to a problem during the shipping, and even if it holds now, because the previous owner fixed it with glue, I was considering to change that specific part, but I would like to keep the display because it works perfectly, even after I updated the firmware to the 25kmh version.
So basically it is possible to change only the plastic that holds the display, without changing the whole thing?
Thank you very much!
Matteo
Im having problem locking the magnets together phone folded, the magnet can't seem to hold is it a factory defect or are the magnets of the qicycle really weak, or if it an alignment problem. Thanks
thanks for this wonderful article
“Der Akku ist eine komplexe Baugruppe, was einen Ersatz zur puren Verschwendung macht, wenn einzelne Teile nicht mehr funktionieren. “
—Das stimmt, deshalb gibt es Akku Spezialisten wie mich (www.ebike-workshop.com) die hier auch nur die (verschlissenen) Zellen tauschen können. (natürlich inkl. Punktschweißen, Kapazitätstests, Funktionstests, optionale Leitungserhöhung durch moderne Hochleitungszellen von SAMSUNG usw..)
since changing the frontwheel tire severalproblems have developed with the motor.
1. the motor starts before pedaling begins.
2. the motor appears to be on continually, thus the available energy from the akku
is very rapidly reduced.
is a reset possible or any suggestions to deal with the problems ?
I have opened and reconnected the cable connection for the motor on the front fork
during the tire change.
the power for the bike was switched off during the repair.
Hei!
A have the same problem. I changed the tires and since then motor starts before pedaling begins and if I stop pedaling motor still runs.
Hello! The seatpost of my qicycle loosened and crashed into a stone, the bottom part bent and I can't straighten it Anyone know where to get a spare. Thank you
Take a look over here, maybe you’ll find some information in this answer section: Where can I buy spare parts of Mijia QiCycle Folding Electric Bike?
I found This page by searching for qicycle accident and need to share my experience. After buying it brand new and using it 5 times to go from home to the tennis court 1km from my house when I was ridding it the welds on the steering column between it and the handle bar cracked open and the handle bar detached completely from the steering column. I had several traumas on legs hands, head and shoulder and an acromic clavicular dislocation level 5. Now Im gonna have to do a surgery to fix my shoulder and as I imported this $@$* from another country there is no company I can sue in my country. I recommend you all to keep an eye on this welding and replace it with something safe or tou might not be as lucky as I was.
How to change Qicycle Boot Logo by Grimor:
After 3 years my bike starts to drive on it‘s own and powers up to 120 watt for 8 seconds after last pedal movement - which unit would you change first?
Hi all, I just bought a brand new qicycle but I noticed that when moving the front wheel in reverse there is a little resistance if moving slowly that disappear when moving faster. When spinning the front wheel normally there is no resistance at all. Do you think it is ok? Thanks in advance
Do you have teardown for the Qicycle EC1? (model: TDP02Z). My EC-1 won’t charge only after 1 time use. Can you help find out What the problem might be? Thanks.
Hello everyone, I’ve a Xiaomi Mi Qicycle bike, i used it for a few months but a day at some point the screen changed: doesn’t shows me the speed modes anymore and there is no electrical drive anymore. The mode is set one BO+ and i can’t change it. The only options on the display are SET, SUM and INFO. I checked the cables and it seems they are all in place and not damaged. Does anybody know what the problem can be? Somebody that had the same problem? thanks
Gab es hier eine Lösung ? Ich habe das gleiche Problem Mein Rad hat keine 300 km gelaufen
Is bms locking after disconnect from cells ?
A non-electronic question: Here with my EF1, the front steerer tube has a bent screw. I think the pull was a bit intense sometimes. Now the folding mechanism can’t be fixated properly anymore and the steerer tube folds ocasionally.
My question is: Where can I get a replacement screw? Does anybody know the specs what screw to look for?
I found one, by the way, in my local screw shop. No online options, only good old shop owners could help me out with the correct screw.
huedrant -
Hi,
Do you know the manufacturer name and P/N of the charger connector (the one you connect to the bike) ?? I bought a QiCycle charger but its connector does not fit my bike which is a XIAOMI one… Connectors are similar but not the same….
Hi thank for that very close look to the bike. I wonder what's the size or specs of bottom bracket. Mine makes too much noise I need to replace it.
Hello guys,
I bought this bicycle. At least I thought I bought this, but it turned out there is 2nd generation after 2020. I wanted to modify to full throttle but it has a torque sensor in the bottom bracket. Do you have any idea how can I manage a modification?
I received the bike for free but i have some issue :
· Battery won't charge anymore, The charger light stay green.
· monitor won't start
· Battery led blink 10 times only when i pushed the button when the charger is plugged.
· I tried the trick by reversing the front wheel, but the charger light still stay green
Then
· I've managed to dismount the battery and charge it to a benchtop power supply at the maximum it can do : 30v and 1.5a ( limits of the benchtop )
· Battery giving me 19v before charging (Black & white wire ) and 21v (black and Red wire)
Results
Still impossible to charge the battery ( voltage is too low i think ) but i'll try again to reverse the front wheel with an Electric drill.
Actually there is still all the led blinking 10 times when and without Charger this time.
Do you think there is any hope to revive the bloc? There is any chance that the BMS is broken due to a direct charge ?
Maybe should i charge each battery individually ?
I ran into a car on my 1 year old bike (their fault). Result: bent fork, damaged head pole and broken front rim. No shop in Germany will fix it for me because they are not the standard parts - as noted here in this page!
If you need parts and you are in Germany - check out Kleinanzeigen, maybe I can help you get back running!
Hello i got the qicycle second hand, but here in Norway its got max speed of 20km, but i want it to go max by the law and that is 25km. i need to change the dashboard to a chinese one because the international version dont have bluetooth, i was hoping that you had a guide on how to remove the part, but i couldent find one, where do i unplug the dashboard?
Hello, do you know how to fix Qicycle that turns off randomly? It was turning off randomly while I was riding it but now it won’t turn on at all. Any help appreciated
I have experienced this too. Check that the battery is fully inserted inside the case.
Larry -
Für Europa mit nur 75kg Traglast nicht zu verkaufen.
Gerhard Hallermayer - 답글
One question please ananda hub is rated at 30 nm torque while xiaomi says only 7.3nm …any suggestions?
rott74 - 답글
Se non si accende il computer di bordo ma la batteria è carica cosa si fa?
pamarotta - 답글
