주요 콘텐츠로 건너뛰기
Huawei Mate 20 Pro Teardown
12 단계
Huawei Mate 20 Pro Teardown: 0 단계, 이미지 2개 중 1개 Huawei Mate 20 Pro Teardown: 0 단계, 이미지 2개 중 2개
  • Just like in the P20 Pro, the USB-C charging port is mounted to a large flex cable. This means if the charging port fails, you'll only have to replace the main cable—instead of a more expensive daughterboard, as in the Google Pixel 3 XL.
  • Another similarity to the P-Series: no 3.5 mm headphone jack. USB-C headphones are included along with a 3.5 mm adapter.
  • Yet, the Mate 20 and Mate 20 Lite both still have a headphone jack. Maybe Huawei isn't quite sure if USB-C alone is the future.
  • The other port, a SIM reader, is mounted to a small board, and planted near the coin-style vibration motor.
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
