주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Huawei P20 Pro 수리는 자사의 서비스 설명서를 사용하세요.
  1. Huawei P20 Pro Teardown, Huawei P20 Pro Teardown: 1 단계, 이미지 3개 중 1개 Huawei P20 Pro Teardown, Huawei P20 Pro Teardown: 1 단계, 이미지 3개 중 2개 Huawei P20 Pro Teardown, Huawei P20 Pro Teardown: 1 단계, 이미지 3개 중 3개
    • Winter spring is coming and so is the new flagship from Huawei. Let's have a quick look at those flourishing specs:
    • 6.1-inch OLED touchscreen with 2240 × 1080 resolution and an aspect ratio of 18.7:9
    • Octa-core Kirin 970 with Mali-G72 MP12 GPU and a dedicated NPU
    • Triple camera 40 MP + 8 MP + 20 MP, ƒ/1.6 and ƒ/2.4 main camera unit by Leica
    • 24 megapixel (no that's not a typo) ƒ/2.0 selfie camera
    • 128 GB storage and 6 GB RAM
  2. Huawei P20 Pro Teardown: 2 단계, 이미지 2개 중 1개 Huawei P20 Pro Teardown: 2 단계, 이미지 2개 중 2개
    • Unlike Samsung, Huawei has opted to notch their display around its camera and earpiece speaker.
    • That said, the P20 Pro seems a little lukewarm on the notch front—the EMUI offers its user the option to ''hide'' the notch.
    • The notch isn't the only thing Huawei borrowed from Apple, it sports an iPhone X-style 1.4 mm mesa with two cameras and a more modest iPhone 6-style "button" for the monochrome sensor.
  3. Huawei P20 Pro Teardown: 3 단계, 이미지 3개 중 1개 Huawei P20 Pro Teardown: 3 단계, 이미지 3개 중 2개 Huawei P20 Pro Teardown: 3 단계, 이미지 3개 중 3개
    • Stacked against (under) the P10, this new Huawei comes with some beefed up dimensions: 155 × 73.9 × 7.8 mm (6.10 × 2.91 × 0.31 in) and 180 g in weight.
    • Flipped over, we see evolution in action: Two cameras bad, three cameras good!
    • The 40 MP and 8 MP cameras work together to get a 3x optical zoom. The 20 MP monochrome camera brings more details and extra sharpness.
    • Since the P20 Pro's "extra" cameras live on the back, and it doesn't need Face ID hardware, its notch takes up a bit less real estate than the iPhone X it takes after (on the right).
    • Sizing aside, there's also some interesting notch geometry to consider.
  4. Huawei P20 Pro Teardown: 4 단계, 이미지 3개 중 1개 Huawei P20 Pro Teardown: 4 단계, 이미지 3개 중 2개 Huawei P20 Pro Teardown: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    iSclack
    $24.99
    • But enough about the outsides—in teardown land, it's what's inside that counts.
    • Eliminating pesky pentalobes was a welcome move, but no screws at all? Time to try our luck with the trusty iSclack.
    • To our surprise the P20 Pro opens almost as easily as a flower in the spring sun. Almost. We've never had to use an opening pick on a flower...
    • This teardown is really starting to bloom, look at all that techy nectar—er, is this metaphor getting away from us?
  5. Huawei P20 Pro Teardown: 5 단계, 이미지 3개 중 1개 Huawei P20 Pro Teardown: 5 단계, 이미지 3개 중 2개 Huawei P20 Pro Teardown: 5 단계, 이미지 3개 중 3개
    • We go to remove the back cover and are foiled! No fingerprint scanner back here and there's still a cable primed to be ripped during opening.
    • Looks like Huawei opted to mount the laser autofocus sensor on the rear case to stack it over the cameras.
    • We finally get our hands on some screws and make quick work of the NFC antenna and motherboard shield.
    • That's an NFC antenna, not a wireless charging coil—that crackable glass back is just for show, and for getting broken...
  6. Huawei P20 Pro Teardown: 6 단계, 이미지 2개 중 1개 Huawei P20 Pro Teardown: 6 단계, 이미지 2개 중 2개
    • Finally, we come to the brains of this operation—the motherboard—and wrestle it free from its various connectors.
    • Huawei once again sticks to its usual motherboard design, opting for a wider battery and a smaller board than some other Android phones.
    • The trio of cameras comes along for the ride, holding fast to the board, with the rear flash module in tow.
    • So many options, which to investigate first—cameras, or motherboard? We opt for the peepers and take the front-facing camera along for the ride.
  7. Huawei P20 Pro Teardown: 7 단계, 이미지 3개 중 1개 Huawei P20 Pro Teardown: 7 단계, 이미지 3개 중 2개 Huawei P20 Pro Teardown: 7 단계, 이미지 3개 중 3개
    • The three rear cameras get by with just two connectors—the main camera and the monochrome camera share one port, while the telephoto camera gets the other all to itself.
    • From the side we can compare the relative elevations:
    • Left: 20 MP (monochrome ƒ/1.6). Middle: 40 MP (main camera ƒ/1.8). Right: 8 MP (telephoto ƒ/2.4)
    • Lastly, we've got all four eyes lined up for inspection, including the P20 Pro's selfie cam with only 24 MP.
    • Samsung's time atop the smartphone camera rankings leaderboard lasted less than a month. Incredibly, the Pixel 2 is still holding its own in the top 5 with just a single main camera.
    • The P20 Pro may not have a fancy dual-aperture lens, but it can laser focus. And deep focus. And phase focus. And contrast focus. Basically, it does a lot of fast focusing.
    • Officially, only the little 8 MP telephoto cam gets hardware OIS—the others, saith Huawei, rely on Kirin's Neural Processing Unit for things like predictive focus, settings for over 19 different scenes, and filter effects like bokeh.
    • That said, this sure looks like OIS hardware to us—three OIS hardwares, to be exact. Are you holding out on us, Huawei?
    • The primary RGB camera uses a 1/1.7 inch sensor (for reference: iPhone X 1/2.9 inch, Samsung Galaxy S9+ 1/2.55 inch) and has a maximum ISO of 102,400—ready for nightly skyline shots and party pix.
  8. Huawei P20 Pro Teardown: 9 단계, 이미지 3개 중 1개 Huawei P20 Pro Teardown: 9 단계, 이미지 3개 중 2개 Huawei P20 Pro Teardown: 9 단계, 이미지 3개 중 3개
    • Oh what the heck. We're as curious as you are, so here are the triplets completely dissected. You won't get more teardown for your money—wait, this is free.
    • And while we're at it, let's also take a closer look at the sensors.
    • In the middle is the 1/1.7 inch RGB sensor, with the 1/2.7 inch monochrome sensor cozying up to its left. On the right we see the telephoto with a 1/4 inch sensor.
    • Probably some sort of memory near the image sensors for the first two cameras from the left.
  9. Huawei P20 Pro Teardown: 10 단계, 이미지 2개 중 1개 Huawei P20 Pro Teardown: 10 단계, 이미지 2개 중 2개
  10. Huawei P20 Pro Teardown: 11 단계, 이미지 2개 중 1개 Huawei P20 Pro Teardown: 11 단계, 이미지 2개 중 2개
  11. Huawei P20 Pro Teardown: 12 단계, 이미지 2개 중 1개 Huawei P20 Pro Teardown: 12 단계, 이미지 2개 중 2개
    • IC Identification, continued:
    • Texas Instruments DRV2605 haptic driver
    • Texas Instruments LM3642 boost LED flash driver
    • Skyworks SKY13351-378LF GaAs SPDT switch
    • STMicroelectronics LSM6DSM 3-axis accelerometer/gyroscope
    • AKM Semiconductor AK09918C 3-axis electronic compass
    • Richtek RT8095GQW 2 A synchronous step-down converter
    • Probably RF switches
  12. Huawei P20 Pro Teardown: 13 단계, 이미지 3개 중 1개 Huawei P20 Pro Teardown: 13 단계, 이미지 3개 중 2개 Huawei P20 Pro Teardown: 13 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    iFixit Adhesive Remover
    $19.99
    • We usually don't like barriers between us and battery replacements, but we might make an exception for this modular charging port. That'll be a painless replacement!
    • Since we got this far without heat, we stay cool and attack the battery glue with some drops of magic. Wait just a tick—then, opening pick.
    • As smartphone batteries go, this one's a heavyweight—4,000 mAh at 3.82V, or 15.28 Wh.
    • That beats the Samsung Galaxy S9+ (13.48 Wh) and the iPhone X (10.35 Wh) by far and is on par with its kinsman the Mate 10 Pro. To be fair software has a big effect on power efficiency.
  13. Huawei P20 Pro Teardown: 14 단계, 이미지 3개 중 1개 Huawei P20 Pro Teardown: 14 단계, 이미지 3개 중 2개 Huawei P20 Pro Teardown: 14 단계, 이미지 3개 중 3개
    • We turn our focus to the bottom of the frame and find a tiny daughterboard, hiding amongst a loudspeaker and vibrator motor.
    • Compared to the battery extraction, the glue securing this collection of parts is a breeze—albeit a sticky one.
    • But where's the headphone jack!?
    • Only the P20 Lite comes equipped with an aux port, whereas the vanilla and the Pro are a little more "courageous".
    • Good thing that charging port is modular, because it'll be doing double duty with headphones and charging cables!
  14. Huawei P20 Pro Teardown: 15 단계, 이미지 3개 중 1개 Huawei P20 Pro Teardown: 15 단계, 이미지 3개 중 2개 Huawei P20 Pro Teardown: 15 단계, 이미지 3개 중 3개
    • Time for one last iOpener/pick song and dance—for this refrain: display removal!
    • We make the display assembly like a banana and ''split.''
    • The display lifts out of the body, but only after the display cable makes a harrowing journey through a hole in the mid frame.
    • Luckily this repair will probably only happen to a broken screen—unluckily this common repair requires tunneling through a well-adhered glass back and the battery.
  15. Huawei P20 Pro Teardown: 16 단계, 이미지 3개 중 1개 Huawei P20 Pro Teardown: 16 단계, 이미지 3개 중 2개 Huawei P20 Pro Teardown: 16 단계, 이미지 3개 중 3개
    • Display separated, we're left with not much intel. However, one item does remain.
    • Some gentle prying and the home button is freed!
    • Lacking Face ID hardware or iris scanning, this phone still uses the "archaic" physical button. No word on whether it's locked to its motherboard.
    • In an unusual twist, the proximity and brightness sensor is buried under the display in the midframe—making for a rather anticlimactic end to our teardown.
  16. Huawei P20 Pro Teardown: 17 단계, 이미지 1개 중 1개
    • Time to move on! Throw a last glance at the insides of the three-eyed phone from Huawei and look forward to more teardown fun from iFixit!
    • Want to see inside your own P20 Pro without taking it apart? Check out this layered wallpaper and download it on your phone!
    • Wanna be the first to break the teardown news? Sign up for our press list and get the inside scoop!
  17. 최종 의견
    • Many components are modular and can be replaced independently.
    • Replacing the battery is possible but at the expense of some time and effort.
    • Double the risk for breakage with glass front and back.
    • Replacing the screen requires going through at least two layers of adhesive and some disassembly.
    수리 용이성 점수
    4
    수리 용이성 10점 중 4점
    (10은 가장 쉬운 수리를 뚯함)
작성자
9다른 기여자 명과 함께
Tobias Isakeit
회원 가입일: 03/31/14
123,935 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,131개를 작성함
댓글 48개
we should always cultivate habit of repairing the broken gadgets and reuse them. else e waste is going to grow like !&&* and kill us. Thanks I fix for your job
Shashidhar AM - 답글
the best teardown site. I wish you start franchisee in India too.
www.drtechnno.com
Painreliever - 답글
Why only a 4 out of 10? This is like the only flagship that doesn't require heat to get into, and you say in the article that everything is modular…
Stefan A - 답글
I would give only 1 point to every flagship phones which back hold by double sided adhesive tape, these phones are fuckingly expensive and the only thing holds it together is cheap tape, if i pay the price of an used car for a phone then i want screws, not double addhesive tape.
kirchner david -
Please do a Huawei P20 Lite Teardown
;0
Humam Tarabishi - 답글
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 142
지난 30일: 375
전체 시간: 215,652
