주요 콘텐츠로 건너뛰기
Huawei Mate 20 Pro Teardown
6 단계
Huawei Mate 20 Pro Teardown: 0 단계, 이미지 2개 중 1개 Huawei Mate 20 Pro Teardown: 0 단계, 이미지 2개 중 2개
  • ...which are easily removed after disconnecting two additional flex cables. Praise our good old friend the spudger!
  • The Mate 20 Pro has three rear cameras:
  • Top right: 40 MP, ƒ/1.8, 27 mm-equivalent wide angle lens
  • Bottom right: 20 MP, ƒ/2.2, 16 mm-equivalent ultra wide angle lens
  • Bottom left: 8 MP, ƒ/2.4, 80 mm-equivalent telephoto lens with 5x optical zoom
  • The P20 Pro's monochromatic camera is ditched for an ultra wide angle lens, ideal for landscape and macro shots (at a minimum focal distance of 2.5 cm).
  • Even with three cameras, Huawei says the brains behind this hardware is what will really make your images shine.
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
