주요 콘텐츠로 건너뛰기
Gateway ID47H07u Teardown
4 단계
Gateway ID47H07u Teardown: 0 단계, 이미지 2개 중 1개 Gateway ID47H07u Teardown: 0 단계, 이미지 2개 중 2개
  • After the screws are removed from the top and bottom, you will find that the entire base is still held down by small clips all around the laptop.
  • I found it easiest to start from the front and work my way around, using a Flathead screwdriver to pry it apart from the palm rest.
  • The second picture shows the heatsink for the Intel GMA 3000 Graphics chip located on the opposite side of the motherboard to the touchpad. On the top of it is a sticky thermal pad that helps to distribute heat to the base.
  • That thermal pad on the heatsink has a double function, in that it is stuck to the base and would need a little effort to separate them from each other.
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
