주요 콘텐츠로 건너뛰기
Gateway ID47H07u Teardown
6 단계
Gateway ID47H07u Teardown: 0 단계, 이미지 3개 중 1개 Gateway ID47H07u Teardown: 0 단계, 이미지 3개 중 2개 Gateway ID47H07u Teardown: 0 단계, 이미지 3개 중 3개
  • The speakers are located near the front of the laptop, and connected by separate cables.
  • There is only one screw that is holding the motherboard to the casing, and is located by the Wi-Fi module at the front/left of the laptop. It is indicated by an orange circle.
  • There is tape near the front center of the laptop which is the last thing holding the motherboard in place after the screw has been removed. Give it a tug, and it will give way.
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
