주요 콘텐츠로 건너뛰기
Gateway ID47H07u Teardown
7 단계
Gateway ID47H07u Teardown: 0 단계, 이미지 3개 중 1개 Gateway ID47H07u Teardown: 0 단계, 이미지 3개 중 2개 Gateway ID47H07u Teardown: 0 단계, 이미지 3개 중 3개
  • Here is the motherboard pulled from the system, with the accessories in their respective positions.
  • The second picture is the motherboard on the flip side.
  • The third picture I included shows the base after it has been stripped of its Motherboard and parts.
  • You will also see that the hinges have been removed at this point. There are simply three screws (2 Left / 1 Right) which bind it to the casing. Make sure to pull the Wi-Fi cable before removing the screen entirely.
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
