해당 분해도에 사용된 도구
소개
It's mid-October and great weather for Apple picking! We've been eager to sink our teeth into a new Mac, so we've brought home a fresh, locally-sourced refresh of the 21.5" iMac: the iMac Intel 21.5" EMC 2889. What's inside this juicy new device? Let's find out. It's teardown time!
Looking for this iMac's pixel-packed twin? Check out our teardown of the iMac Intel 21.5" Retina 4K Display.
Find us on Twitter, Instagram, or Facebook for more tech news.
The 2015 edition of the 21.5" iMac has some newfangled specs:
1.6 GHz dual‑core or 2.8GHz quad‑core Intel Core i5
8 GB (4x2 GB) of 1867 MHz LPDDR3 RAM (Configurable to 16GB)
Intel HD Graphics 6000 or Intel Iris Pro Graphics 6200
1 TB (5400-rpm) hard drive, configurable up to 1 TB Fusion Drive or 256 GB of flash storage.
802.11ac Wi-Fi + Bluetooth 4.0
As tempted as we are to play with the new Magic things, we briefly turn our attention to the
port siderear of this refreshed iMac. -
The ports on the rear: headphone jack, SD card slot, four USB 3.0, two Thunderbolt 2, and gigabit ethernet.
This iteration iMac keeps the standard 21.5" model number, A1418 but adopts a new EMC number: 2889.
Thanks to our specially designed iMac service wedge, opening is a breeze. The wedge keeps the hinge solid while you work—no flop, no slop.
Nope, there's no pizza here folks. We're just using our handy iMac opening tool to cut the display adhesive. We're on a roll!
Just as with the previous generation, the display cables on the new iMac keep the opening procedure from being totally painless.
The multi-talented iMac opening tool helps us slice away the last of the adhesive.
We have separation—and the display's away!
Time to see what this machine is really packing...
Like previous iterations, this iMac display gets its own full set of control hardware:
Texas Instruments BUF16821 Programmable Gamma-Voltage Generator
Richtek RT8250 Synchronous Step-Down Converter
ST Microelectronics 404RP K516
Winbond W25X20CL 2 Mb Serial NOR Flash Memory
Parade DP627HDE DisplayPort LCD timing controller
Texas Instruments TPS54231 Step-Down Converter
Texas Instruments TPS65161 Bias Power Supply for TFT LCD Panels
Are we lost in time or are does this look exactly the same as last year's 21.5" iMac?
We've yet to see something new or interesting here—if you're really itching to see how the speakers, hard drive, and fan come out, check our previous gen guides for details!
Next up—the logic board:
Intel SR26C Core i5-5250U 1.6 GHz Processor (3M Cache, TurboBoost up to 2.70 GHz) with Intel HD Graphics 6000
Samsung K4E6E304EE-EGCF 2 Gb LPDDR3 1867 MHz SDRAM (4 chips for a total of 8 GB)
Broadcom BCM5776 Gigabit Ethernet Controller
Texas Instruments LM4FS1EH SMC Controller
Adesto AT45DB021E 2 Mb SPI Serial Flash Memory
National Semiconductor 545AR6SU
Delta 8904C-F Filter
Intel DSL5520 Thunderbolt 2 Controller
Cirrus Logic 4208-CRZ Audio Controller
Macronix MX25L6473E 64 Mb Serial Multi I/O Flash Memory
Vimicro VC0359 Camera Processor
Intersil ISL62383CHRTZ Power Supply Controller
Intersil ISL95826
We also take the time to remove the AirPort card, but it's more of the same ol', same ol'.
See the 2013 teardown for details on this bad boy if you really gotta know.
iMac 21.5" EMC 2889 Repairability Score: 1 out of 10 (10 is easiest to repair)
Cutting the tape to open the iMac isn't too difficult with the right tools, but it must then be replaced to complete any repair.
The RAM is still soldered to the logic board—you're stuck with what you bought.
The Fusion Drive connector is again missing from the logic board, killing all hope of storage hacking.
The CPU is soldered to the logic board, and cannot be replaced or upgraded.
The glass and LCD are fused together, increasing the cost of replacement.
댓글 13개
Is it not a 1.6 ghz i5 but a 3.1 ghz intel i5
The 1.6 ghz is a non-retina mac. The only 21.5 2015 retina model has a 3.1 ghz i5 with Intel Iris Pro Graphics 6200
:D
This is a basic, entry level computer for people who want an iMac but can't afford one. Don't be harsh with entry level product that nobody would consider upgrading.
It's not the rear side, it's the stern.
It would be nice to have picked up a BTO with 256 or 512GB flash storage to see what the bus speed is. Apple only talks in generalizations about the speed being 2.5X faster but is that only for the 27" or also for the 21.5"? Maybe you'll get a BTO 27" for your take apart.
When you look at a BTO 21.5" iMac, getting the quad-core i7, the possibility of real fast flash storage, then the only thing holding it back is the 16GB RAM limitation. This configuration is not a basic entry-level computer (except for the RAM).
Amazing how people buy a median hardware their weight in gold. Here in Brazil, Apple put the sale this computer imaginable $ $ 3,840 ...
