해당 분해도에 사용된 도구
동영상 개요
소개
What’s that on our teardown table? It’s a big phone! A small tablet! AirPower!? No, it’s the iPad Mini! This year Apple revisited their smallest tablet, bucking industry trends by keeping the Mini's screen small and bezels big. Did Apple stick to tradition all around, or will we be treated to an interior redesign? Looks like we’ll have to tear this tablet down to find out!
Can't get enough teardown? Here's where to get more: Follow us on Facebook, Instagram, or Twitter for the latest teardown news. For iFixit delivered, check out our newsletter.
This tablet may be mini, but it has some big specs:
7.9-inch (diagonal), LED-backlit Retina True Tone display with 2048 × 1536 resolution (326 ppi)
A12 Bionic SoC with 64‑bit architecture and embedded M12 coprocessor
8 MP rear camera + 7 MP FaceTime HD camera
Wi‑Fi (802.11a/b/g/n/ac) with dual channel (2.4 GHz and 5 GHz) and MIMO support + Bluetooth 5.0
19.1 Wh rechargeable lithium-polymer battery
Three-axis gyro + accelerometer + barometer + ambient light sensor
Spoiler alert: judging by the X-rays, it's not a downsized new iPad Air. It looks exactly like an upgraded iPad Mini 4.
The new Air, meanwhile, is based on the last-generation iPad Pro 10.5". (Stay tuned for our Air teardown, coming in about a day.)
Meanwhile, Apple also sells the iPad 6 (or just "iPad"), which itself is a reworked version of the original iPad Air.
We pull a cellular-capable iPad Mini 4 from the lab to confirm our suspicions. Headphone jack: check. Big bezels: check. Home button: check.
About the only exterior clue that gives away the new model is its model number, A2133—oh, and the loss of those regulatory markings on the back, which all live in software now.
After all that glue, we're treated to some less frustrating fasteners.
Knowing Apple's penchant for goofy screw heads, we brought our whole set of drivers. Thankfully this part of the Mini hasn't changed—we're just dealing with standard Phillips heads here.
Our drivers make short work of those screws and we remove the bracket covering the display and battery connectors ...
... and it brings along a friend! Turns out the battery flex connector is now adhered to that cover bracket, automatically disconnecting the battery when the bracket is removed. Nifty!
Notice the clean lines and muted colors in Apple's foray into abstract art. The second image is extra abstract thanks to X-rays.
Let's channel our inner art critic and try to spot some differences between the newest Mini and its predecessor:
Different battery model, with updated (i.e. incompatible) connectors
Rated for 19.32 Wh, it matches the last Mini's, has less than the standard iPad's 32.9 Wh, and comes in a little over the Galaxy Note9's 15.4 Wh.
Upgraded front-facing camera module
Updated ambient light (True Tone) sensors
A migrated set of microphones
Despite their similar hardware, iPads continue to lag way, way behind iPhones in their construction—this home button being a perfect example. On iPhones this is an easy, elegant swap, but here it's still a mess of glue, even after all this time.
Elsewhere on this display, we blast the shields off and smoke out the chips underneath:
Parade Technologies DP815 Display Port timing controller (likely)
Texas Instruments TPS65195 clock level shifter
Texas Instruments TPS65144 LCD Bias w/ integrated gamma reference
Intersil ISL24879 precision programmable LCD reference voltage generator
STMicroelectronics M24C64-F 64 Kb Serial EEPROM memory
This Mini inherits the 7 MP ƒ/2.2 front-facing camera setup we first saw in the 10.5-inch iPad Pro.
With the cameras out of the way, we get a close look at the new upper microphone array, now centered near the selfie cam.
Next, the logic board comes free after a good struggle against the kragle underneath. (Why do iPads always feel like they're assembled by Lord Business?)
Let's see what kind of silicon Apple managed to squeeze in here:
Apple APL1W81 A12 Bionic SoC, layered over Samsung K3UH4H40AM-MGCL 3 GB LPDDR4X DRAM
Toshiba TSB3243VD1190CHNA1 64 GB flash memory
Apple/USI 339S00551 Bluetooth/WiFi module
Broadcom BCM15900 touchscreen controller
Apple 343S00286-A0 and 343S00282-A0 power management ICs (left to right)
NXP Semiconductor CBTL1612A1 display port multiplexer
NXP Semiconductor 100VB27 (SN100V) NFC controller
With this iPad Mini in pieces, we'll conclude our teardown! What did we learn?
The iPad Mini continues to be (mostly) its own entity—not quite a shrunken down iPad, nor a miniature iPad Air.
After a number of conflicting experiences ultimately leading up to this Mini's glued-in battery, we're officially not optimistic anymore about seeing adhesive pull tabs for iPad batteries.
That said, it's time to give this iPad a repairability score!
- A single Phillips driver takes care of all the screws.
- Many components are modular and can be replaced independently, but the Lightning port is soldered to the logic board.
- Battery replacement is possible, but still unnecessarily difficult.
- Gobs of adhesive hold many parts and cables in place, complicating all repairs.
- Removing the home button is tough, and will be required for display replacement if you want to keep Touch ID functionality.
최종 결론
수리 용이성 점수
(10은 가장 쉬운 수리를 뜻합니다)
댓글 16개
It's not going to be any harder to repair than the mini 4
Is the mini 5 Touch ID home button slightly positioned lower than mini 4? So old screen protector cannot aligned properly
Justin Lim - 답글
What DAC is in it?
is the same display on iPad mini 4?
Jesus Ruiz - 답글
Help my iPad screen is broken and touch is working
Should I screen replacement from aliexpress and fix it myself?
I’d like to point out that the microphone placement by the selfie cam isn’t new for the 5. My 3 sitting next to me has them in that exact spot, due to it being a Wi-Fi only model. On the cellular model they are moved near the rear camera. Otherwise it’s about time this got an update, now to retire my 3.
