주요 콘텐츠로 건너뛰기
필요한 것
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. iPod Touch 6th Generation 수리는 저희 서비스 설명서를 사용하십시오.
  1. iPod Touch 6th Generation Teardown, iPod Touch 6th Generation Teardown: 1 단계, 이미지 1/3 iPod Touch 6th Generation Teardown, iPod Touch 6th Generation Teardown: 1 단계, 이미지 2/3 iPod Touch 6th Generation Teardown, iPod Touch 6th Generation Teardown: 1 단계, 이미지 3/3
    • With the same A8 processor and M8 coprocessor as the iPhone 6, it's hard not to get excited about the next-generation iPod Touch. Let's check specs:
    • 4-inch 1136 x 640 pixels (326 ppi) Multi-Touch IPS Retina display
    • 802.11a/b/g/n/ac Wi‑Fi + Bluetooth 4.1 wireless technology (a whole .1 better than the 5th gen!)
    • Six-axis gyro + accelerometer
    • 8 MP, 1080p iSight camera with ƒ/2.4 aperture and 1.2 MP, 720p HD Facetime camera with ƒ/2.2 aperture
    • Shiny new model number: A1574
    • Being that the iPod Touch hasn't seen a full-blown update since 2012, we'd like to see what we're up against.
    • Fortunately, we brought friends. With superpowers.
    • Thanks, Creative Electron!
    • Cry havoc and let fly the X-rays.
  2. iPod Touch 6th Generation Teardown: 3 단계, 이미지 1/3 iPod Touch 6th Generation Teardown: 3 단계, 이미지 2/3 iPod Touch 6th Generation Teardown: 3 단계, 이미지 3/3
    • This new Touch now comes in gold, in addition to blue, pink, (Product)Red, silver, and space gray.
    • The bottom of the device contains no surprises with a now-familiar Lightning port, headphone jack, and speaker grille.
    • Unlike recent iPhones, this Touch lacks a Touch ID sensor. Although it sacrifices Apple Pay, this is good news for repairability since Touch ID buttons are paired to their corresponding processor.
    • On the other side, the inside, we catch a glimpse of the home button and Lightning connector.
    • The little curved prongs help your Lightning connector snap into place, and stay there.
  3. iPod Touch 6th Generation Teardown: 4 단계, 이미지 1/3 iPod Touch 6th Generation Teardown: 4 단계, 이미지 2/3 iPod Touch 6th Generation Teardown: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    iSclack
    $24.99
    구매
    • Heat. iSclack. Repeat—this digitizer/LCD panel is no match for our opening procedure.
    • The adhesive on this display seems tougher than last time, but maybe we're just rusty after a year without an iPod refresh.
    • With the display assembly out of the way, we're one step closer to the innards.
  4. iPod Touch 6th Generation Teardown: 5 단계, 이미지 1/2 iPod Touch 6th Generation Teardown: 5 단계, 이미지 2/2
    • We're eager to delve deeper into this new Touch, so we grab a screwdriver and set to work on extracting the EMI shield.
    • Lifting the shield, we get a glimpse of familiar territory. So far things look pretty darn similar to the 2012 vintage.
    • We won't get our hopes up, but maybe changes made with the processor bump include separating a few components off the soldered-together mess of the 5th gen.
  5. iPod Touch 6th Generation Teardown: 6 단계, 이미지 1/2 iPod Touch 6th Generation Teardown: 6 단계, 이미지 2/2
    • We've been down this road before, and we're pretty confident in our technique for getting the battery out. Unless of course, something has changed...
    • And something has! Looks like the new Touch has peel-out adhesive tabs securing the battery, an update to battery-securing tech we saw in the iPhone 5s. (Although we're scratching our heads about how to peel out a tab that's under the logic board).
    • This Touch totes a 3.83 V, 3.99 Wh battery with a rating of 1043 mAh, as opposed to the 3.7 V, 3.8 Wh, 1030 mAh rated battery found in the 5th Generation Touch.
    • Even with the Touch's advertised performance increases over the previous generation, Apple claims that the battery in this new iPod should supply up to 40 hours of dubstep music, or up to 8 hours of video playback.
  6. iPod Touch 6th Generation Teardown: 7 단계, 이미지 1/2 iPod Touch 6th Generation Teardown: 7 단계, 이미지 2/2
    • After the battery comes the lower assembly, home to the Lightning connector, speaker, microphone, headphone jack, and home button switch. Say that five times fast.
    • In lieu of that wiggly yellow flex cable, a new, straight ribbon cable connects the lower assembly to the underside of the logic board.
    • Despite the new cable, Apple has yet to come to their senses and stop soldering this assembly directly to the logic board. Nuts!
  7. iPod Touch 6th Generation Teardown: 8 단계, 이미지 1/2 iPod Touch 6th Generation Teardown: 8 단계, 이미지 2/2
    • A little bit of careful spudgering goes a long way.
    • We pop off these connectors and are free to separate the two assemblies—the rear case assembly, and the "everything else" assembly.
    • Leftover in the rear case:
    • Antenna assembly
    • Battery adhesive (oops)
    • Snarled volume button/power button/rear flash/microphone cable assembly
  8. iPod Touch 6th Generation Teardown: 9 단계, 이미지 1/3 iPod Touch 6th Generation Teardown: 9 단계, 이미지 2/3 iPod Touch 6th Generation Teardown: 9 단계, 이미지 3/3
    • With a gentle flick of the wrist, the rear-facing camera is free and ready to pass inspection alongside its cousin, the iPhone 6 camera...
    • For your viewing pleasure: the 8 MP iPhone 6 camera (left) and the 8MP iPod Touch camera (right).
    • Physical size serves as a pretty accurate indicator of relative quality. Despite the equal pixel count, the Touch's camera lacks some of its cousin's finer features, such as the sapphire crystal lens cover and auto image stabilization.
    • The Touch's ƒ/2.4 aperture also falls short of the 6's ƒ/2.2.
    • File away this X-ray image of the iPod's primary camera. If rumors can be believed, the next iPhone may far outshine the sensor seen here.
  9. iPod Touch 6th Generation Teardown: 10 단계, 이미지 1/3 iPod Touch 6th Generation Teardown: 10 단계, 이미지 2/3 iPod Touch 6th Generation Teardown: 10 단계, 이미지 3/3
    • Turning our attention to the "everything else" assembly, we quickly set to work on liberating the front-facing camera, and find ourselves facing a tangle of display cables. It's a good thing our teardown engineer has the touch it takes to handle this messy bundle.
    • With some deft tweezing, we are able to extract the front panel.
    • The display is almost the same as previous Touches, but hey, it has a white bezel now!
  10. iPod Touch 6th Generation Teardown: 11 단계, 이미지 1/2 iPod Touch 6th Generation Teardown: 11 단계, 이미지 2/2
    • Let's touch some of these chips, shall we? This logic board is packing:
    • Apple A8 APL1011 SoC + SK Hynix RAM H9CKNNN8KTMRWR-NTH 1 GB LPDDR3 RAM (Same as iPhone 6, but underclocked to 1.10 GHz per core)
    • NXP Semiconductors LPC18B1UK ARM Cortex-M3 Microcontroller (better known as the M8 Motion Coprocessor)
    • Toshiba THGBX3G7D2KLA0C 128 Gb (16 GB) NAND Flash
    • InvenSense MP67B 6-axis Gyroscope and Accelerometer
    • Universal Scientific Industrial 339S0231 Bluetooth/Wi-Fi Module (Probably based on Broadcom BCM4354)
    • Broadcom BCM5976 Touchscreen Controller
    • Texas Instruments 343S0645 Touchscreen Controller
  11. iPod Touch 6th Generation Teardown: 12 단계, 이미지 1/2 iPod Touch 6th Generation Teardown: 12 단계, 이미지 2/2
    • More chips, more fun.
    • Apple 338S1116 Cirrus Audio Codec
    • NXP Semiconductors 1610A2 Display Interface Controller
    • Texas Instruments TPS65730A0P Power Management IC
    • Apple 338S00040-AZ Power Management IC (presumably a variation of the 338S1251-AZ PMIC found in the iPhone 6)
    • X-ray bonus round! Let's not forget our closer look at the uber-powerful A8 processor.
  12. iPod Touch 6th Generation Teardown: 13 단계, 이미지 1/3 iPod Touch 6th Generation Teardown: 13 단계, 이미지 2/3 iPod Touch 6th Generation Teardown: 13 단계, 이미지 3/3
    • iPod turtle Touch 6th Generation Repairability Score: 4 out of 10 (10 is easiest to repair)
    • While very difficult, opening the case and replacing components is not impossible.
    • The battery is adhered with pull tabs that should aid in battery replacement.
    • Many components are soldered together, requiring either a very difficult or a very expensive repair if any one part breaks.
    • There are no external screws. Instead, a combo of clips and adhesive makes it difficult to open the case.
    • Ribbon cables connected to the logic board run over the top and connect on the bottom, making it difficult to remove the board or disconnect the cables.
    • And of course, a big high-five to our pals at Creative Electron for their awesome images and expertise!
댓글 25개
how to disassembly the metal shield on the logic board to acces chips ? Hot air ?
KoSLoW - 답글
The top shield pops off but then the support assembly that holds the shield will cover some components. It was a real pain trying to clean out corrosion in the upper right corner. Can be removed via hot air though.
Joe -
iFixit didn't mention the new, much larger (and therefore louder) speaker thanks to the removal of the Apple Loop connector! That's a real win!
Mark Ingram - 답글
What about the Hard Drive? I didn't see one any where in there. I have a 32GB model and I would like to upgrade to a SSD, is that possible? Mine constantly needs to be rebooted for some reason (in fact now it won't even reboot). Is there a way to fix it?
Martin Simons - 답글
There is no hard drive. All memory is solid state (IC’s) soldered to the logic board.
oldturkey03 -
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 57
30일 전: 215
전체 시간: 191,760
