학생-기여 위키
자사 교육 프로그램의 멋진 학생들이 이 위키를 만들었습니다.
Device Gets Too Hot
Device tend to overheat.
Inadequate Ventilation
Overheating can be caused by inadequate ventilation under the fan. Elevate laptop to create space and air to cool computer.
Damaged Fan
Overheating can be caused by damaged or dusty fan, Check and clean fan. If fan still does not work, replace fan. A guide to repair the fan can be found below:
https://support.hp.com/ca-en/document/c0...
Replace guide: HP Envy x360 m6-w101dx Fan Replacement
Touchpad Unresponsive
Device Touchpad is frozen.
Computer Might be Frozen
Check if the computer and operating system is unresponsive as well, as computer could just be frozen. Hold the power button down to turn off device then turn it back on after 10 seconds.
External Device
Some USB input device automatically disable the touchpad when connected. Remove all Input device and restart computer.
Battery
The advertised battery life is an expected 8-9 hours however, Users have complained about only getting approximately 2-4 hours of battery life.
Screen Brightness
Max screen brightness drain battery faster than other lower levels. Reduce the convertible’s screen brightness to conserve battery power.
Balanced Performance Settings
Make sure that the Windows 10 power plan is set to Balanced Performance to conserve battery power.
Graphics Intensive Programs
Consider which programs you are running; some programs, like graphics-intensive games, will deplete the battery faster. Uninstall programs that require heavy graphics.
Peripherals
Multiple Peripherals like external hard drive, external mouse and keyboard drain the battery. Remove peripherals from the device while they are not is use
Device would not hold a charge
Device needs power to work.
Re-plug Device
Device may not be plugged in properly. Check to see if device is properly plugged in. Disconnect and re-connect charger to device.
Faulty Power Adapter
Faulty or damaged power adapter may cause device not to charge, replace power adapter.
Battery
Damaged battery may cause device not to hold charge. Replace battery. A guide to replace the battery can be found below:
‘SD card not found’ Error
Cannot use SD card with device
Damaged SD card
Make sure the SD card inserted into device is not damaged. You can test this by inserting another SD card into the device.
SD card Panel not connected to Board
Disconnected memory card panel from device won’t work.
Faulty SD Card Panel
A damaged SD Card panel won’t work as well
댓글 0개
