How do you adjust the primary chain on a 1100 sportster?
After getting primary noise from case i discovered my primary chain is loose what is the easiest way to adjust the primary chain ?
좋은 질문 입니까?
좋은 질문 입니까?
skully ferguson, "you need to remove an inspection cover, which has a reusable rubber gasket. With the cover off and the transmission in neutral, you push up on the chain and measure how far the chain moves when you push up on it. For a big twin it should be 5/8 to 7/8 inch (16 - 22 mm) when the engine is cold, and for a Sportster it should be 3/8 to 1/2 inch (9.5 - 12.7 mm) when the engine is cold. This measurement is for the TIGHTEST section of the chain, and chains do sometimes wear unevenly and get stretched in places. For this reason, you should rotate the chain 5 or more times and re-check the adjustment to find the tightest spot in the chain before doing any adjusting" there is a decent video about it right here. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 9
30일 전: 27
전체 시간: 2,450
