주요 콘텐츠로 건너뛰기
The original Xbox is Microsoft's first widely popular video gaming system. It has an easily identifiable black case with 'XBOX' emblazoned on the top and front. Repair is easy with common tools.
171 질문 전체 보기
Error 13 on non-modded XBOX
Its been a long time since I have worked on an original XBOX. As soon it tries tto boot up, we get an error 13. The system appears to never have been opened and therefore it has not been modded. Is there a way to fix it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
Kevin Wells, check this first "13 - kernel - Dashboard launch fail (due to missing/bad key, or anything else that would prevent it from running) and the dashboard didn't specify why it failed.
The error it gives is because of the incompatibility between the (older) dashboard (4920) that older slayer cd installs and the new dashboard/kernel versions found in some new xbox's and found in xbox's that have been connected to xbox live (when you go on xbox-live, it'll upgrade your dashboard file to i believe it is now 5659.03. This dasboard is incompatible with the dash that (old) slayer cd installs (for example 2.5 or lower) for you.
(In detail, in the eeprom chip there is a kernel which is incompatible with the dashboard (4920) that slayer installs.)
So what do you do to fix it? You can use the dashupdate found on most new xbox games! Be sure to 1st unplug your ethernet cable before you do so!!!
Besides that, just use a good installation disc and all is fine. Use a 2.6 slayer or something similar" from here. Let us know if this works, or what you tried besides this. Good Luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Just as an FYI, I haven't spent any time on this unit but the Slayer CD won't do anything on this XBOX. It is stuck in a clock loop where you can't boot anything without first adjusting the clock but you can't get to the clock without getting past the error. I beleive the only way to fix it would be to plop the hard drive into an xbox that has the clock information saved on it and get it up and running there. Once the drive has been restored and functional then I should be able to switch it back to the first xbox and be good to go.
댓글 달기
귀하의 답변을 추가하세요
Kevin Wells 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 2,037
