주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
Step 2 of disassembly
i have a problem in step 2 in the manual for disassembly of the iPhone 3gs iPhone 3GS Front Panel Assembly Replacement.
The problem is that I only have the glass following me up with my suction cup, not the display itself. I don't want to pry in there, but what else is there to do? The glass is only loose in the home button end and I'm not sure I can continue to take the whole glass out.
The glass have been repaired once, so I realize this must be affecting how things are with my phone.
When the glass is loose on its own like this, what can I do to get the display assembly to come up so I can exchange my battery?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
Press glass back down perfect. Then using hairdryer, heat up glass so the adhesive strongly attaches to the glass again. Let it cool all the way. Then carefully try the suction cup removal.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Well, that might work, but I think the job done on it seems to be dodgy. There's no other way to lift the display? Couldn't the hair dryer actually damage the phone?
I'm trying to find out if I can remove the glass without the display following up, lift the display out separately, get new adhesive for the glass, or possibly if I need to get new glass too. That's a bit expensive though. I saved $20 on the glass repair, but paying for it now instead. :-/
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Adhesive is more tacky when warm, just warm it up a bit, so you get some adhesion.
댓글 달기
답변을 추가하세요
MiB 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 502
