주요 콘텐츠로 건너뛰기
Android 2.3 "Gingerbread"를 실행하는 Samsung Galaxy S II는 Samsung Electronics가 설계, 개발 및 판매한 스마트폰입니다.
201 질문 전체 보기
phone dropped in sea water
Whilst on holiday last week I had my personal mobile in a waterproof ( or so i thought) bag and this was dropped in the sea. Straight away, after realising that the bag was not as waterproof as I hoped, I pulled the phone apart dried it with paper towels and left it to dry.
I have thoroughly dried it out, hot hotel balcony and at home a radiator, then a bag of uncooked rice (5 days now).
However I have since got home and read online that I should have rinsed the phone in tap / de ionised water or alcohol first, prior to drying it and that the residual salt is likely to foul it up if I turn it on... (Makes a lot of sense if you stop to think about it - rather than panicking about getting it dry.)
Not wishing to completely wreck it. I have not yet turned the phone on or rewet the phone..
What would you recommend to hopefully bring the phone back to working order without further knackereing the phone.
I am a little cautious as I do not have to pay my £200 excess for water damage on my insurance.
Would rinsing the phone now, do anything to remove the now dried up salt? what would be the best rinse - de ionised water or isopropyl alcohol?
Any other advice?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Gareth, I am certain that you are running into corrosion damage from the salt water. I would recommend that you disassemble your phone totally. You can find a disassembly guide on here. Clean all the parts with high grade isopropyl alcohol (try 90% and great) and a soft tooth brush or a similar device. You can let all the pieces soak in the alcohol. After that, replace the battery and re-evaluate for any damage. Do not forget to clean the connectors and cable ends, hope this helps. Good Luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
"Clean all the parts with high grade isopropyl alcohol"
Are you sure ?
Alcohol does not dissolve salt (NaCl)
Distilled water does.
That make sense ?
댓글 달기
귀하의 답변을 추가하세요
Gareth 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 7,168
