주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1500 질문 전체 보기
질문 마감됨
Charges from Apple charger but not computer
I have an iPhone 3GS to fix that will charge from the Apple charger but when plugged into a pc it won't charge and shows up as an unknown device that may have malfunctioned. Also when it is plugged into the Apple charger it gets power but doesn't seem to store the charge as it runs out of power quickly as soon as it has been unplugged. Also I have tried cleaning the dock connector but it hasn't fixed it.
Does anyone have any idea what is the problem here?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
I did manage to get it to charge fully with some fiddling and it held it's charge. I replaced the dock connector and now it charges 100% of the time and is correctly detected by the computer. Thank you for the help Turkey and Dan.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
Peter not all PC systems offer power via the USB ports (or very limited power). Check your system manual on what the USB power output is.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Peter Hutchinson, the first thing I would do is to change the battery. It may charge from a charger due to the higher amperage. An AC charger supplies almost twice of what a USB port supplies. "seem to store the charge as it runs out of power quickly as" sounds like the battery for sure. At least it will give you a clean starting point. Hope this helps good luck.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Ok I'll replace the battery and let you know how it goes.
Thanks for the help.
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 697
