주요 콘텐츠로 건너뛰기
The APC RS 1000 is an uninterruptible power supply capable of delivering 600 Watts.
Overload alarm lights and sound
My ups, after 5 years of continuous operation shows the overload's light .
I unplugged the PC and I replaced the battery but I have not solved the problem.
Then I opened it to see if there are components that are burned or leak but nothing.
To be sure I replaced the cooling fan but nothing has changed.
Can anyone give me some tips?
Thank you very much.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 1개
Hi, i had the same problem twice...!!!
My battery was ok, everything was ok but
the beep keep going on, for overload...
Both times i fixed doing these steps...
- Turn off the unit
- Flip over the unit
- Open the battery-cap and turn the power on
- Green Light is flashing
- Try Now (with the green light flashing) to disconnect the battery...
- Now it should be ON with the Empty battery light on (Red light)
- Connect again the battery as it is...
Now it should be ok...!!!
Good Luck...
댓글 달기
답변 5개
선택된 해법
Thanks to all. I have not solved the problem. I replaced the old ups with a new one.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
가장 유용한 답변
Roberto, If it alarms, even with nothing plugged in, then it is possible that one of the MOSFET on your mainboard has failed.
이 답변이 도움이 되었나요?
점수 4
댓글 3개:
metal–oxide–semiconductor field-effect transistor (MOSFET)
http://en.wikipedia.org/wiki/MOSFET
Did you solve the problem? Same problem here, 4 years later..
daigoph@gmail.com
Green light not so always yellow light and 5 Second deep alarm
댓글 달기
- Turn off the unit
Good Luck...
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thank you but I replaced the old ups with a new one. Yours sincerely.
댓글 달기
I too facing the same problem....battery charging process is fine...but when i turn on the inverter it trips and shows overload and keep continuosly beep beeps....pls help me to solve this problem....i expecting board level service suggestions ...thank you
이 답변이 도움이 되었나요?
점수 1
댓글 달기
My problem solved with removing the all cables also power cable wait 5 minute & connect cable again it's working.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Roberto 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 83
전체 시간: 38,774
