Rear headrest will not come down
THe rear head rest in my 2000 S80 ae electrically controlled. I think the switch is blown. Can yo manually get them down? Or how do you check for the electrical problem.
좋은 질문 입니까?
좋은 질문 입니까?
Jack, check the fuses. for the headrest restraint it is fuse #7 (10amp) in the trunk fuse box. If those are okay, check the relay that controls your headrest. In the trunk area fold the left rear trim on the rear corner behind that is the relay box. Look for relay RMI14 on the attached image.
해당 답변은 도움이 되었습니까?
will let you know after i try it.
해당 답변은 도움이 되었습니까?
cannot be the the fuse. one headrest locks in the up position and releases with the dash switch. other one will not lock in up position!
24 시간 전: 0
7일 전: 18
30일 전: 28
전체 시간: 4,061
