The Main Chip In My Kinect Burned
'''the main chip in my kinect is burned because it takes high voltage
how can i fix it ???'''
좋은 질문 입니까?
좋은 질문 입니까?
take a look at this teardown. . since we still do not have any clear identification on which IC has failed, you will have to take a close look at the logic board, identify the burned IC and replace it. The IC's are all SMD and thus you will need a hot air reflow, or reball depending on the IC, work station. Unless you have experience with this, I would suggest to get an old board and practice a lot, or to find someone to replace it for you.
해당 답변은 도움이 되었습니까?
thanks for help and i will try to give it to someone who can fix it and if he failed i will back again to try that with my self
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 814
When you refer to the main chip, give us some more detail about which one. When you say it "takes high voltage" what do you mean exactly?
oldturkey03 의
'''i will explain for you
i bought a new kinect and i don't have xbox 360 so i tried it on computer but it didn't work all work but but no responce from kinect so i backed the kinect to the man who i bought from him the kinect and he said he smell something like burn from kinect, he send the kinect to the company and they said the main ship in kinect is burned because it Subjected to high voltage
and i dont know what can i do ???'''
Islam Abou Seada 의
So where did you plug it into when you tried to hock it up to your computer?
oldturkey03 의
i have cable it work on xbox 360 fat i connected the cable to computer in usb and power cable in Jack
i don't know how could that be happened (high voltage)
all what i said is not matter the problem how could i fix the main ship ??
Islam Abou Seada 의
