주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
Screen replaced - small SIM issue
Hello,
Just a small question. Now I've done 2 screen replacements on an iPhone 4S I everytime have a small issue with the SIM card.
When powering on the iPhone 4S after screen replacement, it doesn't ask for a PIN code. It doesn't give the "no sim" error either.
Solution I found was to reset network settings or do a restore... both worked.
Could anyone explain me why this is, and what's the correct fix to the issue?
Many thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 4개
선택된 답변
thx for the info. last time I connected the iphone to itunes and started recovery. During recovery, itunes just downloading ios 6, not actually doing the recovery yet, i did a reset network settings... problem was solved! so no full recovery seems to be necessary
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
Well, found a solution to this problem.
After changing three screens on iPhone 4S with iOS6. All three with this problem.
The solution I found: Insert the sim before you turn on the phone. Then connect the iPhone to the WiFi. Take the sim card out, and put if back in ;)
Hopefully this will resolve the problem.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It's a bug in iOS6. We are many who are waiting for a fix for this :-) Everytime the battery has been disconnected, you will have to restore in order to make your phone see your SIM card.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Thank you Alex, your solution fixed it for me. I was about to !@#$ bricks! thought i had ruined my friend's iphone 4s for a second! :)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Abeloosf 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,572
