주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2396 질문 전체 보기
My iPhone can not format. Whenever I format its showing error message
I can not be restored my iPhone4. Whenever i restored its showing that message. The iPhone could not be restored an unknown error occurred (1). Please advice me what should I do ?
thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Taj, try to put your phone in DFU-mode and then restore. Connect USB, hold home and power button together, after about 7 seconds the phone will turn off. Keep holding home and power for another 3 seconds, now release the power button while holding the home button for another 10 seconds. The phone should be off with a completely dark screen, iTunes should give a message that your phone is in recovery-mode and should be restored. If that does not work, you also want to try a different USB port, a different computer as well as a different cable. Use a USB port on the back of your computer not through a hub or front panel. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Taj 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,897
