주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The onboard VGA doesn't work
Anyone has any ideas on a Socket 775 Mobo, there is a problems with the on-board VGA, it doesn't work, the only way, would be a alternative graphic card, but i want to solve this by attemptinf fixing?
Any Ideas??
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 5개
가장 유용한 답변
Go to bios on bootup (watch your screen for instructions how--they vary) and check that you don't have on board video turned off in bios. The system board has the ability to do that to prevent conflicts when using a graphic card. If you give us more info on your mobo we can be more specific on how to enter bios settings.
It is possible but not likely your video chip may be bad. Ralph
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
By doesn't work do you mean no video or poor video? Ralph
의
댓글 달기
Does the bios starts? If not it might be a memory problem.Remove one RAM card and turn on the computer. If this doesn't work put the card back and remove the other RAM card and turn on the computer.
Hope this helps.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Check whether your CPU has onboard graphics, failing that, get a cheap GPU that has VGA.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Clear cmos battery
Reset bios setting .
restart.......
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Your CPU may not support On-Bord
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Solanki 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 39
전체 시간: 8,758
