주요 콘텐츠로 건너뛰기
모델 A1225 / Early 2009 / 2.66, 2.93, 또는 3.06 GHz Core 2 Duo 프로세서
164 질문 전체 보기
How to configure ssd as a first drive
Hi, I´m going to install a SSD in my Imac 24 inch 9,1 ( early 2009 ) replacing optical unit and use the HDD as a second unit.
How I Should format SSD to install mountain lion for use it as a system unit?? Should I put TRIM enabled??
Will lost speed if I will install SSD replacing Opitcal unit? or Its better to install SSD in HDD place and keep optical unit?
Thanks in advance and sorry for my bad english.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Hi, Here is a link to a previous answer to your question that may help you. Good luck.
SSD in Optical Drive Bay
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thanks, and what about configuration to use SSD as a system unit??
Once you have the SSD installed and install a working OS on it, all you need to do is go into the startup pref settings and select it as the boot volume (system), and restart.
댓글 달기
귀하의 답변을 추가하세요
Pedro 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 3,199
