주요 콘텐츠로 건너뛰기
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
How do I remove the Control Locked light which prevents starting
After the power returned from the hurrican, the Control Locked light was on. Tried everything to remove or override but nothing worked. What can I do short of calling a repair man?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 26
댓글 13개
Thank you. It worked for me.
Thank you! This worked perfectly!
I had the same problem due to an electrical outage here, I forget the fix, but it's in the manual, scary, but simple fix.
Hi i have the same problem and did not have any success in having any light or sound but the control lock light on. As soon I touch any thing else it will flash 4 times and back to steady that’s it. Any other suggestions? I unplugged it twice already!
I mistakenly tried to turn resolve this by hitting the control lock and when nothing happened I assumed there was a problem. If you press and hold control lock until it counts down 3,2,1 and then off. This turns it off.
댓글 8개 더보기
댓글 달기
답변 13개
선택된 해법
Howard Lowitt, hope everything else is okay after the hurricane. Anyhow, try this first. Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off. If that does not do it, try putting the machine into diagnostic mode.
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
■ Close the door.
■ Push CONTROL/ON (if present on this model).
■ Select the DRAIN/SPIN cycle.
■ Select NO SPIN by pressing the SPIN SPEED touch-pad.
■ Push PREWASH OPTION four times within five seconds. (If PREWASH OPTION is not present on this model, press EXTRA RINSE four times within five seconds.) C:00 will light up on the display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad, then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push PREWASH OPTION touch-pad two times. If PREWASH OPTION is not present on this model, press EXTRA RINSE two times.
If that does not work, or if if it won't enter diagnostic mode, then you may need to replace the main control board. You can get the service manual from here. You can also find plenty of information on here and here as well. Hope this helps, good luck. Stay safe....
이 답변이 도움이 되었나요?
점수 28
댓글 29개:
I tried your sequence to reset my machine and it worked!!! Thank you so much.
AS soon as I hit the drain spin button the Control Locked button went off. THANKS!
Yes, this worked - thanks!
Holding the "End of Cycle Signal" worked for us on our 2008 Duet Whirlpool. Thanks so much!!! 7/9/17 - the Whitelys
OMG! IT WORKED! YOU ARE A GENIUS IN MY BOOK! I was about to call a repairman on a Sunday, can't believe I am not going to spenD that money I don't have! Glad to be a member of this valuable site!!! THANK YOU!
댓글 24개 더보기
댓글 달기
Mine was the "Drain/Spin" button and the "Start" button at the same time.
이 답변이 도움이 되었나요?
점수 8
댓글 5개:
I tried holding the control lock for 3 sec it blinked then stayed on and it won’t let me turn on any other buttons
Worked! Thanks for the help!
Worked for me. Thanks!
Thanks! Drain/spin combo unlocked it for me!
Also worked for me on a 2002 HE3T model
댓글 달기
Press and hold the drain/spin cycle button for 4 seconds should do the trick
이 답변이 도움이 되었나요?
점수 3
댓글 4개:
Thank you. Been working on this for three days! I love you.
Thank you so much it worked drain spin.then end of cycle button. You are the best.
Holding End of Cycle Signal worked for me. Thanks Whitley’s
Washing machine remains lighted when not in use
댓글 달기
Had mice enter the control panel and fray the wires. After making the repairs, the control lock light was on and no suggestions here would fix. Holding the spin speed button and end of cycle signal button for 4 seconds worked however!
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
What you said worked . Thanks so much for the help . GOD bless you and your family
THANK YOU SO MUCH !!!
That suggestion worked for our Whirlpool Model GHW9250ML1 !!! Have been searching for a fix for our washer all day. Husband gave up and was trying to find an appliance repair shop to come out. Our washer is from about 1998 and we couldn’t find the owners manual. YOUR quick fix saved the day, and $$$$$. THANKS AGAIN. Jean W.
Thank you so much. After the hurricane mine wouldn’t go off. And by reading your comments it worked. Saved me some money.
Thanks! Totally worked for me after trying all the other options listed here. Mine is an old whirlpool duet, model GHW9300PW4. Hope this helps someone else.
댓글 달기
On my front loader I had to press and hold the control lock button until it beeped then the LOC light popped off
Update (09/24/2016)
I held down the "control Lock" button on my front loader until it beeped. A few seconds then the LOC error popped off. It happens a lot when I accidentally lean or touch the front of the machine which happens with almost no intent. Plays the on/off tune then powers on or off. This is a design flaw if you ask me.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
Thank you, that worked for me, Lisa.
Thank you it worked for me too :) Tracey
Holding down on the Control Lock button until it beeped, cleared it for me! What a relief, thought I was going to have a service call. Saved me $$$.
Mine doesn't have a control lock button only a contol on and that didn't work holding it or the cancel button
댓글 달기
I tried everything to get the control lock off on my whirlpool duet washer need help bad. I unplugged it for 15 minutes to reset it and still nothing.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Push spin speed and then end of cycle. And mine started right up good luck.
Thank you it went off Let’s see how long it stays off Thank you very much
댓글 달기
I had to push Add steam button and start. Automatically corrected it and was able to wash clothes and finish tidying up!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
my GE machine needed me to hold both warm rinse an d auto soak (the 2 of which locked controls in the first place) for about 10 seconds...now working fine.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Not an answer. Control lock goes off intermittently and returns. It will go off after any button is pushed for three seconds except the end of cycle button.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Chris Werner. Is it a question? Something like "Why does the Control lock go off intermittently and returns?"
Sorry, I was following the questions and answers that preceded - The last one was, "Was this answer helpful? None of these worked so are not the answer for my situation. Unplugging for extended period worked for a bit but it beeped intermittently throughout. Now that doesn't work either. I have tried all of the button combinations. Can't get it into diagnostic mode.
Question: does it need a new control unit, perhaps?
댓글 달기
The control board is locked.it starts up but i cant choose anything.actually buttons don't work.what should I do?need help
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Thanks for the good ideas to bring it. I know a lot more. :) [url=http://balltoyou.com][size=1px]ดูบอล[/size][/url] :J
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have a whirlpool duet sport washer. When I power on the control panel looks fine. I choose a cycle press start. The door locks and stays locked. The dance/ pause button light comes on. After pressing the pause/ cancel button, it stays lit? Door still locked, the the “add a garment” light turns on. Then the changing the cycle doesn’t work. The time remains stays the same as the cycle chosen initially. At this point no buttons work. I did a diagnostic test and the only code that appears is f-24 (temperature sensor, but I replaced the sensor with a brand new one). Help please! And what does this error code have to do with the door?
THANK YOU!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
None of this works and there is no control lock button just a light and control on button. None of this stuff worked! I cleaned the filter that was on the hose and now I’m having this problem of control lock!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Howard Lowitt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 55
지난 30일: 283
전체 시간: 219,358
