주요 콘텐츠로 건너뛰기
Repair guides for the Kenmore 80 Series of washing machines, manufactured by Kenmore.
122 질문 전체 보기
Kenmore 80 series drive tub seal replacement
I replaced the tub seal on my Kenmore direct drive washing machine as shown on this youtube video (Whirlpool/ Kenmore Washer Repair: Drive Tub Seal Replacement (part #383727) - YouTube). When I had removed the outer tub I had noticed caked up dirt/grease along the bottom of the outer tub near where it would contact the inner tub and mounting stem. Thinking this was dirt, I cleaned it off and replaced the tub seal. I've put everything back together and now the tub makes a high pitched noise while in spin mode and does not spin correctly. Was I wrong to have cleaned that dirt off or was I supposed to grease the seal/mounting stem or space between the two tubs? What kind of grease is used for this?? Any help would be appreciated!!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
I do not think that it was grease. It should not need any. I would double check for proper alignment of the inner tub. It does sound like it may be to tight on the drive shaft or out of alignment.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Luis 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 20
전체 시간: 2,326
