주요 콘텐츠로 건너뛰기
Model M7886 / 450 MHz 또는 500 MHz PowerPC 7400/7410 (G4) 프로세서
17 질문 전체 보기
change cd drive to dvd -r/w, and airport card possible?
I have a Power Mac G4 Cube and I would like to put a DVD-R/RW drive to replace the CD drive. Is this possible? If so what model drive should I buy? Also,I'd like to put an airport wifi card in the machine as well... is the new Airport Xtreme compatible, or should I use the older Airport card?
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Hi, you can put a DVD Drive in (not sure about disc burning though), as shown here:
But you can only have an Airport Card (not Extreme):
Hope that helps
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
just out of curiousity- what app is that?
This is an old comment, I know by now, but thanks anyways.
댓글 달기
Actually you can as long as you remember these things the wireless is going to be limited to a or b connectivity only because it uses the older airport card as long as the drive is slot loading it really doesn't matter because you can remove the ice adapter off of the back of the current drive and attach it to any drive
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Gaspar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 5
전체 시간: 3,233
