주요 콘텐츠로 건너뛰기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
904 질문 전체 보기
질문 마감됨
850 mAh battery for an 7G iPod Classic?
Hi, I have a 7th Gen iPod Classic, and I want to change the battery in it. So I wonder if it would be possible to put a thick 850 mAh battery in it, by changing the rear panel of my iPod into a bigger one ? Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Yes it is possible, BUT that will extend the clearance between the case and the hard drive. This could lead to a loose hard drive and may damage the drive, the cables, or the connector.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
I want to put a 240gb HDD in it, so that's not a problem. If I keep the 160gb HDD, can I put some paper or something in it to avoid the clearance ? And will I have to take a Ipod Video or thick 6th Gen Ipod Classic rear panel ?
The iPod video will not fit your front, so you'll have to go with the 6th gen. Try to use some packing foam to fill the space.
Hi. I have an issue : the battery seems not to charge (actually, the battery logo is full in a few seconds while I hadn't yet charge the battery, and it drains in a few seconds too.) So what am I supposed to do ? Thanks
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,980
