주요 콘텐츠로 건너뛰기
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
Where do you add transmission fluid
Where do you add transmission fluid to 2005 Chevy cavalier?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
선택된 해법
Bob, Your Cavalier may not have a dip stick. Transmission fluid is not added or checked like in the old days, there is no fill tube or dipstick. Transmission fluid is added after removing the vent cap (cap normally red) located at the top of transmission by the shift linkage. Do not overfill transmission. There is a fill level plug (may be 12mm hex head) that will have to be removed, plug is located above middle of the pan, to the left of the bell housing, a few inches from the bottom of the housing. With the vehicle at operating temperature on level ground, as soon as trans. fluid starts running from the fluid level/full hole, stop adding fluid and wait for fluid to stop running from hole,reinsert the plug, transmission is full.
Pic's and further instruction can be seen at attached link. Good luck.
http://www.justanswer.com/chevy/2e38e-20...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
How many quarts you fluid does a 2005 Chevy Cavalier take
이 답변이 도움이 되었나요?
점수 0
댓글 달기
bob, you add fluid through the small dipstick tube. It has the red or orange handle on it, behind the back side of the motor. It is short and hard to spot, but it looks like a regular dipstick tube. Use a very small funnel to add fluid through the tube. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 -1
댓글 달기
답변을 추가하세요
bob 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 22
전체 시간: 8,050
